I’m trying to script from the output of g.proj. Here is an example of the output from 4 different locations. Note the differences.
The order of the key : value pairs varies somewhat.
Why can’t an xy location have units? Why isn’t it’s output proj : xy?
In the PROJ_UNITS field, sometimes there are American meters and other times British metres in the values. In the keys, there is meter and meters for the same key name.
These are all trivial when you are just looking at the output on the screen, but a pain when you want to script this and check for values. It would help a lot if we could standardize these things.
- a LatLon location
-PROJ_INFO-------------------------------------------------
proj : ll
ellps : wgs84
a : 6378137
es : 0.0066943800
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meter : 1.0
- a UTM location
datum : nad27
nadgrids : conus
proj : utm
ellps : clark66
a : 6378206.4000000004
es : 0.0067686580
f : 294.9786982000
zone : 13
unit : meter
units : meters
meters : 1.0
- an XY location
XY location (unprojected)
- a Lambert location
name : Lambert Conformal Conic
proj : lcc
ellps : clark66
lat_1 : 60
lat_2 : 46
lat_0 : 44
lon_0 : -68.5
x_0 : 0
y_0 : 0
no_defs : defined
unit : metre
units : metres
meters : 1
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
