If have a map with values from 0-255 I create a set of color rules such that
0% = green
100% = red
GRASS will create a color table that will assign a nice gradient of colors from 0:255:0 to 255:0:0 to the values from 0-255.
Is there any way when querying a single cell of that map to know what color has been assigned to it? Similarly, is there any way to know what color has been assigned to any value in the 0-255 range?
Michael
Center for Social Dynamics and Complexity
Arizona State University
I was contemplating a wxPython histograming module, like the TclTk profiling
module, and liked the option in d.histogram of being able to use the color
table for the histogram colors. But this seems like a pretty intensive batch
of calculations to do it.
Michael
On 4/12/07 4:08 PM, "Glynn Clements" <glynn@gclements.plus.com> wrote:
0% = green
100% = red
Set a 1x1 region around the cell, then r.out.ppm | pnmnoraw | sed.
Or r.mapcalc 'out = (r#map * 256 + g#map) * 256 + b#map', query the
composite map and decode the category number.
Set a 1x1 region, r.mapcalc "tmp = $value", r.out.ppm ...
Seriously; this is how d.rast.edit.tcl does it.
Yeah; we could probably do with a "r.what.colors" module.
>> such that
>> 0% = green
>> 100% = red
Glynn:
Michael:
profiling module, and liked the option in d.histogram of being able to
use the color table for the histogram colors. But this seems like a
pretty intensive batch of calculations to do it.
you could try "r.profile -c" with a profile which starts and stops at
the cell center (length=0). Also it should be very simple to add a flag
just like "r.profile -c" to r.what, if that helps.
But probably the most direct solution is a SWIG-Python interface to the
libgis color-lookup fns themselves.
Michael:
> >> such that
> >> 0% = green
> >> 100% = red
Glynn:
Michael:
I have a version of r.what that I modified to optionally output RGB
color. If interested I could commit to CVS?
Bob
> Michael:
It may be useful to have that feature in r.what, although there would
still be some use for a module which looks up the colour for a
user-supplied value (e.g. d.rast.edit.tcl needs to be able to
determine the colour for new values which don't yet exist in the map).
This is fine, but I'm afraid that it won't help planned implementation. This
is partly because I didn't phrase my question correctly. What I really need
to know is what color is assigned to a cat value. The idea is to do
histogramming in wxPython. It might be nice to have the histogram show the
map colors like d.histogram can. To do that, I need to know the color
assigned to a cat. However, to get colors by querying every cell in a map
with r.what would take a very long time.
Michael
On 4/18/07 7:05 AM, "Bob Covill" <bcovill@tekmap.ns.ca> wrote:
On Thu, 2007-04-19 at 01:51 +1200, Hamish wrote:
Michael:
such that
0% = green
100% = red
Glynn:
Michael:
Bob
On Wed, 2007-04-18 at 17:19 +0100, Glynn Clements wrote:
> > Michael:
I have committed the change to r.what. It now has a "-r" flag (-c was
taken) that will output the RGB for the selected point.
Please test.
If you are looking to duplicate d.histogram why not use r.stats? This
will output raster values with the percent or area which could be used
for plotting a histogram. If this did work it could be modified to
output the associated raster color along with the other values. Maybe I
am missing the point?
On a related issues I have used a modified version of r.stats for a
while now to create equalized color bars for raster maps. You simply
calculate the distribution over a set number of color breaks, drop a
custom colortable over the breaks and apply with r.colors rules=.
Hope this helps.
Bob
Michael
>> Michael:
>>>>> such that
>>>>> 0% = green
>>>>> 100% = red
>> Glynn:
>> Michael:
> Bob
>> Hamish
>> _______________________________________________
>> grass-dev mailing list
>> grass-dev@grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
On 4/18/07 12:22 PM, "Bob Covill" <bcovill@tekmap.ns.ca> wrote:
Michael,
Hope this helps.
Bob
Michael
Michael:
such that
0% = green
100% = red
Glynn:
Michael:
Bob
I have added such a module, name r.what.color.
Values can be passed either on the command line or on stdin, and the
corresponding colours are written on stdout.
I am missing the point?
In fact d.histogram calls system("r.stats -Cr{c|a}...."); to get the
data it needs for its histogram.
Michael:
I didn't follow this in detail, but with this new -r flag, what is
r.what.color providing?
Is there a need to keep it?
Markus (who always has an eye on too similar modules)
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
Including a "RGB"-flag into r.stats would still be a good thing.
Right now, creating a vector polygon layer with a GRASSRGB-column out of a raster map + colortable needs some manual input or custom shell scripting to set up tthe RGBCOLOR values.
Having a RGB-functionality in r.stats would make this (and other tasks) easier.
Peter
Bob Covill wrote on 04/18/2007 09:02 PM:
Michael:
profiling module, and liked the option in d.histogram of being able >to
the cell center (length=0). Also it should be very simple to add a >flag
>>> was taken) that will output the RGB for the selected point.
> Arbitrary color lookup, not just the value at one specific x,y cell.
> I believe it is useful for Glynn's new d.rast.edit[.tcl] where the given
> cell isn't written for r.what to query.
Anyone willing to write description.html for r.what.color?
the rest of GRASS uniformly uses/expects %d:%d:%d (255:255:255) for that.
suggestion: either use 0x%02x%02x%02x (0xaabbcc) if output is primariliy
meant for sending to Tcl, or %d:%d:%d (255:255:255) if meant to be
useful to GRASS. "ff:ff:ff" seems to be a mix of methods and an anomaly.
or is there another reason?
what RGB triplet pattern does xwPython prefer?
