[GRASS-dev] anyone compiled GRASS 7 on Mac Yosemite?
Has anyone yet tried to compile GRASS 7 on Mac Yosemite (AKA OS X 10.10)?
I will update soon and try it. It would be nice to know if it compiles without any issues.
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
Michael,
Anna compiled it for me.
Below is the configure and some notes. We had to run make for wxGUI from within GRASS and the vector attribute tables do not work
for me at the moment due to sqlite problems - we ran out of time to solve it.
We also used wxPython carbon 3 to see what kind of problems it would have - so some of the GUI panels are cut off so use 2.8
But otherwise it works great so it is worth doing - if you could provide GRASS7 binaries for yosemite that would be fantastic,
Anna is away but I have the machine with me so I can help or at least test.
Thanks for looking into it,
Helena
here are our notes:
./configure \
--with-proj \
--with-x \
--with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include \
--with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib \
--with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj \
--with-gdal=/Library/Frameworks/GDAL.Framework/Programs/gdal-config \
--with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
--with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
--with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
--with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
--with-opengl=aqua \
--without-fftw \
--with-cairo --with-cairo-includes=/Library/Frameworks/cairo.framework/unix/include/cairo \
--with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib \
--with-cairo-ldflags="-lcairo" \
--with-freetype \
--with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include/ /opt/X11/include/" \
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib \
--with-geos=/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config \
--with-sqlite \
--with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib \
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include \
--with-macosx-archs="i386 x86_64"
# run before compilation: export VERSIONER_PYTHON_PREFER_32_BIT=yes
PATH="/Library/Frameworks/PROJ.framework/Versions/4/Programs:$PATH"
export PATH
wxPython carbon 3 has issues - use 2.8
Helena Mitasova
Professor at the Department of Marine,
Earth, and Atmospheric Sciences
and Center for Geospatial Analytics
North Carolina State University
Raleigh, NC 27695-8208
hmitaso@ncsu.edu
http://geospatial.ncsu.edu/osgeorel/
"All electronic mail messages in connection with State business which are sent to or received by this account are subject to the NC Public Records Law and may be disclosed to third parties.”
Michael
____________________
C. Michael Barton
grass-dev mailing list
grass-dev@lists.osgeo.org
Thanks. The versions I now have posted work fine with Yosemite. But I have not yet compiled under Yosemite.
I have a couple of questions:
What is: export VERSIONER_PYTHON_PREFER_32_BIT=yes?
Also, is the SQLite problem something to do with Yosemite or something else?
I’ve also tried with wxPython 3 but it looks bad. So I’m still sticking with 2.8 (which is why we need the 32bit Python).
Here is what I do before compiling
# This is for creating a distributable binary that is backward compatible to OSX 10.7
export MACOSX_DEPLOYMENT_TARGET=10.7
# This stuff is for making sure that it compiles using 32 bit Python
export PATH="/Applications/python/bin32:/System/Library/Frameworks/Python.framework/Versions/2.7/bin:$PATH”
# This is what I do for PROJ
export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
# This is (IIRC) for LAS tools compiling
export CXX=g++
For the broken xml stuff, I’ve just saved versions of menudata.xml. and module_tree_menudata.xml. I drop these into the proper places before making a binary. Can I just run make from the source root from within GRASS to get the same thing?
Michael
C. Michael Barton
On Dec 30, 2014, at 1:36 PM, Helena Mitasova <hmitaso@ncsu.edu> wrote:
Michael,
Helena
here are our notes:
./configure \
--with-proj \
--with-x \
--without-fftw \
--with-freetype \
--with-sqlite \
export PATH
Helena Mitasova
hmitaso@ncsu.edu
NCSU GeoForAll Lab (NCSU OSGeoREL)
Michael
C. Michael Barton
grass-dev Info Page
On Tue, Dec 30, 2014 at 3:49 PM, Michael Barton <Michael.Barton@asu.edu>
This is there to make it compile with 32bit wxPython 2.8. It depends which
Python you use, this works for the default Python on Mac OS:
https://developer.apple.com/library/mac/documentation/Darwin/Reference/ManPages/man1/python.1.html
else?
I haven't had time to look at it.
Yes, there are still a lot of weird bugs, some of them must be fixed in
wxWidgets, some of them I tried to workaround. It would be good if you
could describe "looks bad", there might be some things which i can fix or
at least workaround.
to OSX 10.7
export
export CXX=g++
I think I haven't tried compiling with las tools yet.
the same thing?
It is enough to start GRASS session (without gui) and then recompile (just
the wxpython part is enough) inside the session. That's what works for me.
I don't really try to understand why, it's apparently some problem with
makefiles and setting the right environmental variables. I thought we got
rid of this problem (Martin fixed something) but apparently not.
Anna
Michael
C. Michael Barton
> Michael,
solve it.
test.
> Helena
> here are our notes:
> ./configure \
> --with-proj \
> --with-x \
> --without-fftw \
> --with-cairo
> --with-freetype \
> --with-sqlite \
> export PATH
> Helena Mitasova
> hmitaso@ncsu.edu
10.10)?
without any issues.
>> Michael
>> C. Michael Barton
>> _______________________________________________
