[GRASS-dev] arabic try
hi
  • If I want to use another language like Arabic with interfaces in grass, do I need to compile the grass?
  • I want to build different interfaces in TCL/TK and from them I will call GRASS’s functions, but my interfaces must be in Arabic ,so I ask you: Do I need to translate Grass messages to Arabic
Send instant messages to your online friends http://uk.messenger.yahoo.com
- If I want to use another language like Arabic with interfaces in
No. Language can be set at runtime.
You do need the source code to help with translating new messages. (?)
- I want to build different interfaces in TCL/TK and from them I will
call GRASS's functions, but my interfaces must be in Arabic ,so I ask
Someone has to. Start with the modules most important to you.
see http://grass.ibiblio.org/devel/i18n.php
I don't think that has been updated for Cedric's latest TclTk &
scripting translation updates. Maybe he could give an example?
Hamish
Also, GRASS' text handling is quite primitive, and oriented towards
ASCII and ISO-8859-* encodings. At present, the internationalisation
support is limited to:
1. The use of message catalogues.
2. Support for user-specified encodings in a few specific places
(primarily those related to FreeType).
There certainly isn't any explicit support for right-to-left
languages. Also, any code which uses the curses library will only work
correctly with unibyte encodings (e.g. ISO-8859-*), and not with
multibyte encodings such as UTF-8.
