Hi
Can I use in module prepared for GRASS such constructions:
typedef enum {
AND, /* & */
OR, /* | */
NOT, /* ~ */
IS, /* = */
THEN, /* : */
LBRC, /* ( */
RBRC, /* ) */
START, /* { */
STOP, /* } */
MAP, /* mapname */
VAR, /* variable name */
size /* number of tokens */
} tokens;
char parseTab [size][size] = { /* parser table definition is here */
I mean type enum and enum size variable to initialize table. It compiles on gcc 4.3 but, as I know GRASS has restriction and I'm not sure if such is fully allowed.
thanks for answer
Jarek
typedef enum {
AND, /* & */
OR, /* | */
NOT, /* ~ */
IS, /* = */
THEN, /* : */
LBRC, /* ( */
RBRC, /* ) */
START, /* { */
STOP, /* } */
MAP, /* mapname */
} tokens;
is fully allowed.
In general, if it's valid C89 (use "gcc -std=c89 ..." to check), then
it's fine. Any use of gcc extensions or C99-specific features must be
conditional, with a fallback if those features aren't available.
Similarly, use of functions which aren't specified by C89 should be
conditionalised (non-C89 functions which are specified by POSIX are
okay provided that they're available on Linux, Windows and MacOSX).
Glynn Clements pisze:
typedef enum {
AND, /* & */
OR, /* | */
NOT, /* ~ */
IS, /* = */
THEN, /* : */
LBRC, /* ( */
RBRC, /* ) */
START, /* { */
STOP, /* } */
MAP, /* mapname */
} tokens;
conditional, with a fallback if those features aren't available. Similarly, use of functions which aren't specified by C89 should be
Ok, thanks Glynn. It means I shoud be OK, but I didn't find typedef enum ... in any fo GRASS code, so I asked.
Jarek.
2010/3/13 Jarek Jasiewicz <jarekj@amu.edu.pl>:
see e.g.
http://trac.osgeo.org/grass/browser/grass/trunk/db/drivers/postgres/globals.h#L25
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
