[GRASS-dev] Are the recursive calls a problem in Grass?
Does anyone have an idea or an advice for this problem? GRASS doens’t give me any kind of error message so I don’t undestand where the bug is. It just stop the execution! I hope in your experience.
Roberto
roberto caselli roberto.caselli@yahoo.it ha scritto:
Hello everyone,
I have a question for you. I’m working on a module that uses a recursive call to flow water from a cell to its neighbours. I tested it with some sample raster map but I didn’t see any kind of output on the screen. I saw GRASS started running (i saw the green dressed runner above on the right) and then it stopped with the RUN button available to be pushed again.
I tried to comment the recursive call and everything went well. (I saw the partial results of the execution of my module on the screen).
So I think the problem is due to this recursive call and I’d like to know if there is a way to fix this problem.
Roberto
Tante idee per la salvaguardia del pianeta su
Yahoo! for good.
Yahoo! for good.
Roberto,
please try it on command line. Maybe then the error becomes
visible (GUI may catch it silently).
On Tue, May 6, 2008 at 1:59 PM, roberto caselli
<roberto.caselli@yahoo.it> wrote:
Does anyone have an idea or an advice for this problem? GRASS doens't give
me any kind of error message so I don't undestand where the bug is. It just
Roberto
roberto caselli <roberto.caselli@yahoo.it> ha scritto:
Hello everyone,
I have a question for you. I'm working on a module that uses a recursive
sample raster map but I didn't see any kind of output on the screen. I saw
So I think the problem is due to this recursive call and I'd like to know if
Roberto
Yahoo! for good.
Yahoo! for good.
grass-dev mailing list
grass-dev@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
