[GRASS-dev] Are the recursive calls a problem in Grass?
`I always start my application from command line and the a GUI window`
`opens so I can write the input and press the RUN button. But I don't`
`see any kind of message error inside that window.`
`Roberto`
`Roberto,`
`please try it on command line. Maybe then the error becomes`
`visible (GUI may catch it silently).`
`Markus`
`On Tue, May 6, 2008 at 1:59 PM, roberto caselli`
`<roberto.caselli@yahoo.it> wrote:`
`> Does anyone have an idea or an advice for this problem? GRASS doens't`
` give`
`> me any kind of error message so I don't undestand where the bug is.`
` It just`
`> stop the execution! I hope in your experience.`
`> Regards,`
`> Roberto`
`> roberto caselli <roberto.caselli@yahoo.it> ha scritto:`
`>  Hello everyone,`
`> I have a question for you. I'm working on a module that uses a`
` recursive`
`> call to flow water from a cell to its neighbours. I tested it with`
` some`
`> sample raster map but I didn't see any kind of output on the screen.`
` I saw`
`> GRASS started running (i saw the green dressed runner above on the`
` right)`
`> and then it stopped with the RUN button available to be pushed again.`
`> I tried to comment the recursive call and everything went well.  (I`
` saw the`
`> partial results of the execution of my module on the screen).`
`> So I think the problem is due to this recursive call and I'd like to`
` know if`
`> there is a way to fix this problem.`
`> Regards,`
 Roberto`
`> ________________________________`
`>  Tante idee per la salvaguardia del pianeta su`
`>  Yahoo! for good.`
`> _______________________________________________`
`>  grass-dev mailing list`
`>  grass-dev@lists.osgeo.org`
`>  [http://lists.osgeo.org/mailman/listinfo/grass-dev](http://lists.osgeo.org/mailman/listinfo/grass-dev)`
Yahoo! for good.
Hello Roberto,
I don't have your module command currently hence an example with a common
command:
if you do e.g.
d.rast
the GUI will pop up, if you do
d.rast --help
you will see syntax
d.rast [-oix] map=string [catlist=cat[-cat][,cat[-cat],...]]
   [vallist=val[-val][,val[-val],...]] [bg=color] [--verbose] [--quiet]
the parts in brackets are optional hence you just have to to enter
d.rast map=your_raster
to plot the raster.
If you do the same with your command you will get an error message (or not).
You can change the message output with
g.gisenv set=debug=5 (not too sure about that)
hope this helps, cheers, Martin
Roberto
Roberto,
give
It just
> Regards,
> Roberto
> Hello everyone,
recursive
some
I saw
right)
saw the
know if
> Regards,
> Roberto
> Yahoo! for good.
> Yahoo! for good.
Yahoo! for good.
Thak you very much! Now I can see the message error:
the message is the follow:
Segmentation fault (core dumped)
Martin Wegmann wegmann@biozentrum.uni-wuerzburg.de ha scritto:
Hello Roberto,
opens so I can write the input and press the RUN button. But I don’t
I don’t have your module command currently hence an example with a common
command:
if you do e.g.
d.rast
d.rast --help
you will see syntax
d.rast [-oix] map=string [catlist=cat[-cat][,cat[-cat],…]]
[vallist=val[-val][,val[-val],…]] [bg=color] [–verbose] [–quiet]
to plot the raster.
Roberto
Roberto,
Do You Yahoo!?
Poco spazio e tanto spam? Yahoo! Mail ti protegge dallo spam e ti da tanto spazio gratuito per i tuoi file e i messaggi
http://mail.yahoo.it
was that with 'g.gisenv set="DEBUG=5"'?
can you try with gdb?
instructions here:
  http://grass.osgeo.org/wiki/GRASS_Debugging
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
