[GRASS-dev] Automatic/CI compilation on macOS
Dear all,
I made some updates towards updating the conda recipe for GRASS GIS on macOS by Eric Hutton, but it is not working yet. You can find the WIP PR here:
https://github.com/csdms-stack/grass-recipe/pull/1
You can see the current state in Travis linked from the PR or in GitHub Actions of my fork:
https://github.com/wenzeslaus/grass-recipe/tree/updates-for-7.8-and-above
https://github.com/wenzeslaus/grass-recipe/actions
If you think a different approach is more appropriate and want to try it out, you can consider contributing to the following repository which now, for example, contains a homebrew-osgeo4mac based branch. Again see the current state in GitHub Actions:
https://github.com/GRASS-GIS/grass-gis-experimental-ci/tree/homebrew-osgeo4mac
If you have some ideas for fixing the errors, please let me know, here, by PRs, issues, or links to other repos.
Vaclav
OK - found the ci.
The formula installs, but I get a warning at the end, which results in a warning, which is than interpreted as an error. The warning (which I also get locally) is the following:
If it is the case that you can change the shebang at the beginning of
he script to enforce Python 3 usage.
#!/usr/bin/env python
Should be changed into
#!/usr/bin/env python3
I suspect that this needs to be done in GRASS itself?
Rainer
On 5 Mar 2020, at 09:40, Rainer Krug <rainer_krug@icloud.com> wrote:
Sorry for chiming in so late - haven’t followed GRASS closely and I might raise points which have already been discussed.
I can not comment on conda, as I never used it.
I made a fix on the home-brew-osgeo4mac branch as the test using for the brew test needs the name of the formula. I tried the installation and the brew test locally, and it works.
Where can I see the log from the ci?
There were also discussions on the R mailing list to support Conda, and it definitely has its user base, but O don’t think it is as widely used as home-brew. So supporting both would be the best option.
Especially, if I am not mistaken, the support for the osgeo4mac-grass formula for home-brew is already taken care of by osgeo4mac.
Rainer
On 5 Mar 2020, at 04:58, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Dear all,
Vaclav
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Orcid ID: 0000-0002-7490-0066
Department of Evolutionary Biology and Environmental Studies
University of Zürich
Office Y34-J-74
Winterthurerstrasse 190
8075 Zürich
Switzerland
Office: +41 (0)44 635 47 64
Cell: +41 (0)78 630 66 57
email: Rainer.Krug@uzh.ch
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
On Thu, Mar 5, 2020 at 4:27 AM Rainer M Krug <Rainer@krugs.de> wrote:
OK - found the ci.
Hi, thanks for looking into this. 7.8.2 (and also above) has python3 everywhere in shebang. See e.g.:
$ grep -Irn “/usr/bin/env python[^3]”
scripts/g.extension/g.extension.py:1059: “#!/usr/bin/env python\n”,
scripts/g.extension/g.extension.py:1308: “#!/usr/bin/env python\n”,
(these two are in fact code which is doing the replacement to python3)
Can you please investigate locally where the message coming from?
Vaclav
OK - found the ci.
The message comes from the formula as a Caveat. I think it is always displayed. But at the moment, I am not to sure where the error code comes from, as I get an error code at the end of the brew command of 0 locally.
I will look into this.
Do you know, why there is a
  • uses: actions/checkout@v2
In the action?
It seems, that it will be executed last, and there is no checkout needed.
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
OK - found the ci.
Please ignore the following about the checkout.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
OK - one step closer to success. Now I just have to know the location where the data for the tests can be downloaded from (I guess). Please check the log to at https://github.com/GRASS-GIS/grass-gis-experimental-ci/runs/487969965?check_suite_focus=true for the Basic test and the Thorough test. I will look at the return code later, when the tests are running.
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Everything is in the repo, well, it needs to be, I guess the only question is where in the repo, so:
https://github.com/GRASS-GIS/grass-gis-experimental-ci/blob/homebrew-osgeo4mac/test_thorough.sh
The problem there is probably a bad/missing path to PROJ db. I think it complains during the configuration already, so perhaps correct --with-proj-share will fix it. The runtime way of setting it is PROJ_LIB environmental variable. You can try something along these lines.
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
I am trying to find the file proj.db but can’t find it - can you give me any indication, where it can be found in Linux (home-brew should use similar locations)?
Rainer
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Often it is in /usr/share/proj. Now you can find things like that in the Docker/Singularity/Vagrant configurations included in GRASS GIS source code or in the CIs, e.g., here:
https://github.com/GRASS-GIS/grass-gis-experimental-ci/blob/master/build.sh#L39
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
OK. Looking at the parameters GRASS is compiled with (grass78 —config), I get the following proj related parameter (the complete output at the end of the email):
–with-proj-includes=/usr/local/opt/osgeo-proj/include
–with-proj-libs=/usr/local/opt/osgeo-proj/lib
–with-proj-share=/usr/local/opt/osgeo-proj/share/proj
Which seem to be correct, and proj.db is in the proj-share directory.
08:37 $ ls -la /usr/local/opt/osgeo-proj/share/proj
total 12408
drwxr-xr-x 15 rainerkrug staff 480 Feb 10 11:16 .
drwxr-xr-x 4 rainerkrug staff 128 Feb 10 11:16 …
-rw-r–r-- 1 rainerkrug staff 1183 Feb 10 11:16 CH
-rw-r–r-- 1 rainerkrug staff 728 Feb 10 11:16 GL27
-rw-r–r-- 1 rainerkrug staff 2099 Feb 10 11:16 ITRF2000
-rw-r–r-- 1 rainerkrug staff 3660 Feb 10 11:16 ITRF2008
-rw-r–r-- 1 rainerkrug staff 3468 Feb 10 11:16 ITRF2014
-rw-r–r-- 1 rainerkrug staff 6385 Feb 10 11:16 nad.lst
-rw-r–r-- 1 rainerkrug staff 19535 Feb 10 11:16 nad27
-rw-r–r-- 1 rainerkrug staff 16593 Feb 10 11:16 nad83
-rw-r–r-- 1 rainerkrug staff 232 Feb 10 11:16 null
-rw-r–r-- 1 rainerkrug staff 3915 Feb 10 11:16 other.extra
-rw-r–r-- 1 rainerkrug staff 6234112 Feb 10 11:16 proj.db
-rw-r–r-- 1 rainerkrug staff 32060 Feb 10 11:16 projjson.schema.json
-rw-r–r-- 1 rainerkrug staff 7079 Feb 10 11:16 world
So it looks fine, but I, even locally, get the following error when running the simple test:
08:40 $ grass78 --tmp-location EPSG:4326 --exec g.region res=0.1 -p
Starting GRASS GIS…
Creating new GRASS GIS location …
ERROR: b’proj_get_authorities_from_database: Cannot find proj.db
Here is the complete output from --config:
08:35 $ grass78 --config
x86_64-apple-darwin17.7.0
./configure --prefix=/usr/local/Cellar/osgeo-grass/7.8.2_3 --with-cxx --enable-shared --enable-largefile --with-nls --with-includes=/usr/local/include --with-libs=/usr/local/LIB --with-python=/usr/local/Cellar/osgeo-grass/7.8.2_3/libexec/vendor/bin/python-config --with-tcltk --with-netcdf=/usr/local/opt/osgeo-netcdf/bin/nc-config --with-zstd --with-zstd-includes=/usr/local/opt/zstd/include --with-zstd-libs=/usr/local/opt/zstd/lib --with-readline --with-readline-includes=/usr/local/opt/readline/include --with-readline-libs=/usr/local/opt/readline/lib --with-blas --with-blas-includes=/usr/local/opt/openblas/include --with-blas-libs=/usr/local/opt/openblas/lib --with-lapack --with-lapack-includes=/usr/local/opt/lapack/include --with-lapack-libs=/usr/local/opt/lapack/lib --with-geos=/usr/local/opt/geos/bin/geos-config --with-geos-includes=/usr/local/opt/geos/include --with-geos-libs=/usr/local/opt/geos/lib --with-odbc --with-odbc-includes=/usr/local/opt/unixodbc/include --with-odbc-libs=/usr/local/opt/unixodbc/lib --with-gdal=/usr/local/opt/osgeo-gdal/bin/gdal-config --with-zlib-includes=/usr/local/opt/zlib/include --with-zlib-libs=/usr/local/opt/zlib/lib --with-bzlib --with-bzlib-includes=/usr/local/opt/bzip2/include --with-bzlib-libs=/usr/local/opt/bzip2/lib --with-cairo --with-cairo-includes=/usr/local/opt/cairo/include/cairo --with-cairo-libs=/usr/local/opt/cairo/lib --with-cairo-ldflags=-lfontconfig --with-freetype --with-freetype-includes=/usr/local/opt/freetype/include/freetype2 --with-freetype-libs=/usr/local/opt/freetype/lib --with-proj-includes=/usr/local/opt/osgeo-proj/include --with-proj-libs=/usr/local/opt/osgeo-proj/lib --with-proj-share=/usr/local/opt/osgeo-proj/share/proj --with-tiff --with-tiff-includes=/usr/local/opt/libtiff/include --with-tiff-libs=/usr/local/opt/libtiff/lib --with-png --with-png-includes=/usr/local/opt/libpng/include --with-png-libs=/usr/local/opt/libpng/lib --with-regex --with-fftw --with-fftw-includes=/usr/local/opt/fftw/include --with-fftw-libs=/usr/local/opt/fftw/lib --with-sqlite --with-sqlite-includes=/usr/local/opt/sqlite/include --with-sqlite-libs=/usr/local/opt/sqlite/lib --with-liblas=/usr/local/opt/osgeo-liblas/bin/liblas-config --with-postgres --with-postgres-includes=/usr/local/opt/osgeo-postgresql/include --with-postgres-libs=/usr/local/opt/osgeo-postgresql/lib --with-mysql --with-mysql-includes=/usr/local/opt/mysql/include/mysql --with-mysql-libs=/usr/local/opt/mysql/lib --with-pthread --with-pthread-includes=/usr/local/opt/boost/include/boost/thread --with-pthread-libs=/usr/local/opt/boost/lib --with-macosx-sdk=/Applications/Xcode-10.1.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk --with-macosx-archs=x86_64 --with-opengl-includes=/Applications/Xcode-10.1.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/OpenGL.framework/Headers --with-wxwidgets=/usr/local/opt/wxmac/bin/wx-config
clang
/usr/local/Cellar/osgeo-grass/7.8.2_3/grass78
File “/usr/local/Cellar/osgeo-grass/7.8.2_3/libexec/bin/grass78”, line 2025, in main
index = sys.argv.index(batch_exec_param)
ValueError: ‘–exec’ is not in list
During handling of the above exception, another exception occurred:
File “/usr/local/Cellar/osgeo-grass/7.8.2_3/libexec/bin/grass78”, line 2216, in
main()
File “/usr/local/Cellar/osgeo-grass/7.8.2_3/libexec/bin/grass78”, line 2030, in main
params = parse_cmdline(sys.argv[1:], default_gui=default_gui)
File “/usr/local/Cellar/osgeo-grass/7.8.2_3/libexec/bin/grass78”, line 1951, in parse_cmdline
print_params()
File “/usr/local/Cellar/osgeo-grass/7.8.2_3/libexec/bin/grass78”, line 1862, in print_params
“%s\n” % val[0].split(‘:’)[1].rstrip(‘$"\n’).strip())
IndexError: list index out of range
Any suggestions what the problem is?
Rainer
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
total 12408
Starting GRASS GIS…
This error comes directly from PROJ.
Try
export PROJ_LIB=“usr/local/opt/osgeo-proj/share/proj”
before starting GRASS. This will tell PROJ where its own share data are.
Markus M
clang
main()
print_params()
Rainer
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
total 12408
Starting GRASS GIS…
Try
Does not work:
17:03 $ export PROJ_LIB=“/usr/local/opt/osgeo-proj/share/proj”
:heavy_check_mark: ~
17:03 $ grass78 --tmp-location EPSG:4326 --exec g.region res=0.1 -p
Starting GRASS GIS…
Exiting…
✘-1 ~
17:03 $ ls -la /usr/local/opt/osgeo-proj/share/proj
total 12408
Any other suggestion?
Markus M
clang
main()
print_params()
Rainer
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Hi Rainer,
Unfortunately, I don’t have any update for this, but I thought I will (inter-)link a detailed analysis on grass-user by Veronika and related PR:
[GRASS-user] Problems on MacOS Catalina Installation via Homebrew “Cannot find proj.db”
https://lists.osgeo.org/pipermail/grass-user/2020-March/081377.html
[Bug] Update build GRASS as macOS application #457 (linked comment and below)
https://github.com/OSGeo/grass/issues/457#issuecomment-603575140
Vaclav
total 12408
Starting GRASS GIS…
Try
Does not work:
Starting GRASS GIS…
Exiting…
✘-1 ~
total 12408
Markus M
clang
main()
print_params()
Rainer
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Thanks Vaclav
I will wait and see.If you could please post here if something happens, as I am not following grass-user?
Rainer
On 31 Mar 2020, at 03:50, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Hi Rainer,
Vaclav
total 12408
Starting GRASS GIS…
Try
Does not work:
Starting GRASS GIS…
Exiting…
✘-1 ~
total 12408
Markus M
clang
main()
print_params()
Rainer
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Hi!
Just want to give you an update on the issue. I managed to get CI build working for Mac [1, 2].
In addition I’m working on a bash script-package [3] (based on Michael’s excellent instructions on grasswiki [4]) which uses conda too, for a very simplified procedure to build an app bundle. It is working, but needs testing.
Best,
Nicklas
[1] https://github.com/nilason/grass-gis-experimental-ci/tree/conda-updates
[2] https://github.com/GRASS-GIS/grass-gis-experimental-ci/pull/3
[3] https://github.com/nilason/grass-conda
[4] https://grasswiki.osgeo.org/wiki/Compiling_on_macOS_using_Anaconda
On 31 Mar 2020, at 14:53, Rainer M Krug <Rainer@krugs.de> wrote:
Thanks Vaclav
Rainer
Hi Rainer,
Vaclav
total 12408
Starting GRASS GIS…
Try
Does not work:
Starting GRASS GIS…
Exiting…
✘-1 ~
total 12408
Markus M
clang
main()
print_params()
Rainer
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Hi Nicklas,
Thanks, these look great. What do you suggest as next steps?
It would be great to have at least one of these running in the main repo. I don’t know if we need all, but each has its specifics. An App bundle would make sense as a test of a primary way of distributing. (There is a lot of additional code in grass-conda repo, but we do have a ton of code for Windows packaging in the repo.) Plain build inside conda would be nice and simple for the testing purposes. An actual conda package build, possibly cross-platform in the future, sounds like the right thing to do since conda is already involved.
BTW, I merged your Install.make fix. Please, consider doing more of these. “enable OSX Help Viewer” and other macOS-only cases should go to the main code rather than being a patch. The PYTHON var (Python executable (which is used for ?)) would make sense as something configurable.
Vaclav
On Wed, Aug 12, 2020 at 12:14 PM Nicklas Larsson <n_larsson@yahoo.com> wrote:
Hi!
Best,
Nicklas
Thanks Vaclav
Rainer
Hi Rainer,
Vaclav
total 12408
Starting GRASS GIS…
Try
Does not work:
Starting GRASS GIS…
Exiting…
✘-1 ~
total 12408
Markus M
clang
main()
print_params()
Rainer
Rainer
OK - found the ci.
Found it.
In the action?
Rainer
Vaclav
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
