[GRASS-dev] automatic user font cap building for init.sh
I didn't get any response to my possible patch for init.sh to do this (it was in the iconv thread), so I went ahead and committed it. If GRASS_FONT_CAP and/or GRASS_FT_CAP are set, and they do not exist yet, init.sh will run g.mkfontcap to create them. This will leave the GRASS binary-installed cap files alone (that is, GRASS_FONT_CAP or GRASS_FT_CAP is not set), and will not overwrite existing user cap files that they may have customized. But it gets them started with their current state of installed fonts.
To go along with this, I also set GRASS_FONT_CAP and GRASS_FT_CAP in the OSX app startup to the user's home GRASS support folder. After the first run of GRASS.app, the user can customize these or regenerate them as they like, and not have to worry about permissions to edit the GRASS.app copy.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
GRASS_FT_CAP is no longer relevant; only GRASS_FONT_CAP is used.
Ah, thanks. I forgot to ask what the current status of the switch of the fontcap files was.
I didn’t get any response to my possible patch for init.sh to do this
the OSX app startup to the user’s home GRASS support folder. After
William Kyngesburye <kyngchaosatkyngchaosdotcom>
“Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life.”
  • Marvin
