[GRASS-dev] Avoid the addition of @mymapset in output map name
Hi all!
I’m working on the GUI of my module for clouds and shadows detection in Sentinel 2 images (GSoC 2018 project) and I have some trouble with the automatic addition of the mapset name in the output maps.
I have several input bands imported in GRASS that I convert into float value and rescale using r.mapcalc, each output map should be automatically named with the inputs band name and a suffix (e.g. input: nir - output: nir_float).
When I run the script using the GUI I have an error due to the @mapset automatically added to the output map name (e.g. nir@mymapset_float).
At the moment, I solved the problem with a replace() function but I’m not sure this can be the best solution, do you have any hint?
Following you can find the code:
mapset = gscript.gisenv()[‘MAPSET’]
mapset2 = ‘@%s’ % mapset
b1 = options[‘blu’]
b1 = b1.replace(mapset2, “”)
b2 = options[‘green’]
b2 = b2.replace(mapset2, “”)
b3 = options[‘red’]
b3 = b3.replace(mapset2, “”)
b4 = options[‘nir’]
b4 = b4.replace(mapset2, “”)
b5 = options[‘nir8a’]
b5 = b5.replace(mapset2, “”)
b7 = options[‘swir11’]
b7 = b7.replace(mapset2, “”)
b8 = options[‘swir12’]
b8 = b8.replace(mapset2, “”)
f = ‘float’
bands = [b1, b2, b3, b4, b5, b7, b8]
for b in bands:
gscript.mapcalc(‘{r} = 1.0 * ({a})/{c}’.format(r=“%s_%s” % (b, f), a=b, c=scale_fac), overwrite=True)
f_bands.append (“%s_%s” % (b, f))
Thanks in advance,
Roberta
Hi Roberta,
You can try:
b1 = b1.split(‘@’)[0]
Stefan
Hi all!
b1 = options[‘blu’]
b3 = options[‘red’]
b4 = options[‘nir’]
f = ‘float’
for b in bands:
Thanks in advance,
Roberta
Hi Roberta,
Le Tue, 29 May 2018 13:16:48 +0200,
Roberta Fagandini <robifagandini@gmail.com> a écrit :
Hi all!
I'm working on the GUI of my module for clouds and shadows detection
At the moment, I solved the problem with a replace() function but I'm
A classic solution that you will find in many scripts is using split():
mapname_without_mapset = mapname_with_mapset.split('@')[0]
Moritz
Hi Roberta,
On Tue, May 29, 2018 at 1:41 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi Roberta,
Hi all!
mapname_without_mapset = mapname_with_mapset.split(‘@’)[0]
there is find_file() in lib/python/script/core.py with returns a dictionary of keys/values including the name without mapset
Markus M
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
2018-05-29 14:09 GMT+02:00 Markus Metz <markus.metz.giswork@gmail.com>:
Hi Roberta,
> Hi Roberta,
> > Hi all!
Markus M
With find_file it should work also for maps in different mapset.
Roberta can you test it?
R
> Moritz
2018-05-31 15:08 GMT+02:00 Roberto Marzocchi <roberto.marzocchi@gmail.com>:
Hi Roberta,
> Hi Roberta,
> > Hi all!
Markus M
R
Yes, it works!
Thank you all for your help!
Roberta
> Moritz
