Are there any policies on developers backporting their changes to release branches? Do it theirselves? Ask another to do it (ie you) to keep some review sanity?
I don't want to mess it up in attempting to do it myself. I was hoping it would be as simple as "apply this trunk changeset to that branch", but it looks like I now need to have a local copy of the branch so I can commit the merges. Though, mine are simple enough (mostly), and isolated, that I could just do a diff and commit.
On Mar 24, 2008, at 1:19 AM, Glynn Clements wrote:
William Kyngesburye wrote:
Back in November there was discussion on how to backport in CVS. How
about SVN? I have one old change that hasn't made it to the RCs yet.
On Wed, Mar 26, 2008 at 1:53 AM, William Kyngesburye
<woklist@kyngchaos.com> wrote:
Markus,
release branches?
Yes.
It depends: preferably a developer should be able to
backport him/herself but
- do not break the release branch
- make tests
- only fix bugs, do not introduce new features
If the latter is unclear, it should be discussed on this list.
If someone doesn't want to or cannot commit him/herself, a diff
is appreciated.
Thanks for the clarifications. I'll go ahead with some backport fixes.
- make tests
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
> - make tests
At this point in the RC cycle, it is best to play it very conservative as
RC6 was most likely be the last before 6.3.0 and so any changes you make
in the release branch will go into 6.3.0 with little to no community
testing.
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs
I backported some minor Mac-only bugfixes. They have worked well for me so far. And I did manually apply them to my recent RC binaries, and haven't heard of any problems. A couple were build fixes, so they would only affect those that compiled SVN source.
A pair I haven't done yet (ran out of time this morning), that are companions to Glynn's r29926 and r30066, which were applied to the release branch:
These affect some lib/init stuff, but are important to return what Glynn removed, in another form. These also have worked well for me so far, and are in my binaries, and no reports of problems yet.
Comments?
On Mar 26, 2008, at 5:44 PM, Hamish wrote:
Markus:
- make tests
testing.
release branch:
Comments?
Platform-specific targets should be implemented using make
conditionals, rather than an unconditional target which performs the
test within the commands. IOW:
Comments?
OK, add this to the above list, to be backported (if OK) as a unit:
>> release branch:
>> http://trac.osgeo.org/grass/changeset/30347
>> http://trac.osgeo.org/grass/changeset/30704
>> so
>> Comments?
Makefiles shouldn't hard-code the permissions. The user should be able
to override this by setting INSTALL. Typically. $(INSTALL) will use
755 while $(INSTALL_DATA) will use 644.
On Mar 28, 2008, at 4:43 PM, Glynn Clements wrote:
One minor point:
$(INSTALL) -m 755 grass-xterm-mac $(ETC)
-- Glynn Clements <glynn@gclements.plus.com>
Ah, I must have done that as a quick fix a while back (and it propogated to later changes) without reading the install docs completely (and missed that install defaults to 755).
I have that in my osx makefiles also... on to cleanup...
Oh, looks like all the installs there hardwired the -m 755 flag. I'll let you take care of cleaning up the init makefile if you want.
One minor point:
