I am getting lost in the today's submissions (which is nice).
Anything which I should backport to 6.2?
- recent gis.m fixes - maybe yes
- recent driver fixes - no
- recent freetype changes - no idea
right?
thanks
right?
thanks
For freetype changes (d.m and d.text.freetype), yes.
Huidae
On Wed, Aug 30, 2006 at 09:58:16PM +0200, Markus Neteler wrote:
Anything which I should backport to 6.2?- recent gis.m fixes - maybe yes
- recent freetype changes - no idearight?
thanks
Markus_______________________________________________
grass-dev mailing list
grass-dev@grass.itc.it
Definitely for gis.m. These are bug fixes.
Michael
On 8/30/06 12:58 PM, "Markus Neteler" <neteler@itc.it> wrote:
thanks
Arizona State University
WWW - http://www.public.asu.edu/~cmbarton
Phone: 480-965-6262
Fax: 480-965-7671
Huidae Cho wrote on 08/30/2006 10:03 PM:
Huidae
Please indicate which changes to do. There have been many in the
last few hours, so I am not sure which to take and which to leave.
Can you point me to the submissions here:
http://grass.itc.it/pipermail/grass-commit/2006-August/date.html#end
thanks
Markus,
http://grass.itc.it/pipermail/grass-commit/2006-August/024031.html
http://grass.itc.it/pipermail/grass-commit/2006-August/024032.html
http://grass.itc.it/pipermail/grass-commit/2006-August/024035.html
http://grass.itc.it/pipermail/grass-commit/2006-August/024036.html
http://grass.itc.it/pipermail/grass-commit/2006-August/024037.html
http://grass.itc.it/pipermail/grass-commit/2006-August/024038.html
Thanks.
Huidae
> Huidae
last few hours, so I am not sure which to take and which to leave.Can you point me to the submissions here:
thanksMarkus
Hi Huidae, all,
freetype done (is gis.m not affected for this?) as indicated
below.
Michael: gis.m also done.
A new snapshot (more recent than beta2) is here:
http://grass.itc.it/grass62/source/snapshot/
It's important to test d.m, gis.m and freetype stuff.
On Thu, Aug 31, 2006 at 08:35:50AM -0500, Huidae Cho wrote:
Markus,
http://grass.itc.it/pipermail/grass-commit/2006-August/024038.htmlThanks.
> > Huidae
> thanks
> Markus
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
On Thu, Aug 31, 2006 at 04:12:57PM +0200, Markus Neteler wrote:
Hi Huidae, all,
below.
No. gis.m does not have d.text.freetype support.
Huidae
http://grass.itc.it/grass62/source/snapshot/It's important to test d.m, gis.m and freetype stuff.
> Markus,
> Thanks.
> Huidae
> > > Huidae
> > thanks
> > Markus--
Once all the freetype and font changes are in effect and I get/make a new
binary to work from, I can test these on my Mac (unless someone else wants
to do it).
If there is an advantage of putting a GRASS generated text layer (the new
combined d.text/d.text.freetype?) back into gism instead of the
TclTk-generated text, I can do that. However, it will take a bit of time to
redo the options panel and change the rest of the code.
There is no point in doing this until:
1) all the changes to text layer control and rendering are done (more to do
or is that all?), and
2) we know that freetype text renders on the Mac (the TclTk text shows up
fine on all systems).
I don't know whether you want to try and do this for 6.2 or not, given the
timing.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 31 Aug 2006 09:58:38 -0500
To: GRASS developers list <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] Backporting questionOn Thu, Aug 31, 2006 at 04:12:57PM +0200, Markus Neteler wrote:
Hi Huidae, all,
below.No. gis.m does not have d.text.freetype support.
Huidae
On Sat, Sep 02, 2006 at 12:34:29PM -0700, Michael Barton wrote:
[freetype]
timing.
My suggestion is to not do it for 6.2. It is almost published.
Next week I can do the proposed change of v.bspline to
v.surf.bspline but I would not do heavy (yet untested)
changes.
