I Think I found a problem with OGR datasources linked
in using v.external.
If I change into a directory with shapefiles and then
issue the following to link in the data in "myShapefile.shp":
v.external dsn=. layer=myShapefile output=linked_in
And then change into another directory and issue any command
that wants to work on "linked_in", e.g.:
g.remove vect=linked_in
v.info linked_in
I get:
ERROR: Cannot open layer 'myShapefile'
But when I change back into the directoy where I used
to be when running the v.external command, it works.
So I think v.external should take care to always link
to the absolute location of the source in the file
system (if I specify "dsn=" as an absolute path,
things work fine).
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
