Dear Developers,
does anybody know why batch-grass.sh
from the GRASS FAQ "How to use GRASS in batch mode?"
does not work anymore?
I run the batch-grass.sh script for the last time successfully in May with
whatever cvs version was up-to-date at that time, probably 6.1.
After fiddling with my grass-scripts and cluelessly looking through
batch-grass.sh I tested all 6.x versions and found that my set-up works with
the 6.0 version but not with the newer versions.
Thats why I am wondering what changed in GRASS to that effect. And what do I
need to do, to get batch-grass.sh working again.
I very much appreciate any hints, tips and fixes.
cheers,
robert
--tests-----------------------------------------------------------
simple test with one command:
./batch-grass.sh eifel nwz2 g.region -p
6.0.2 is okay
grass-6.1.0 - 6.3.cvs give the following
./batch-grass.sh: line 62: 16750 Speicherzugriffsfehler $*
providing the grass commands in a file:
./batch-grass.sh eifel nwz2 -file g_commands.sh
grass-6.0.2 again works
and the others fail with this message:
sh: line 1: 17129 Speicherzugriffsfehler g.region -p
with:
grass-6.3.cvs (cvs from 2006-08-17)
grass-6.2.cvs (built from grass-6.2.cvs_src_snapshot_2006_08_12)
grass-6.1.0 (built from grass-6.1.0.tar.gz)
grass-6.0.2 (built from grass-6.0.2.tar.gz)
Robert,
please run the script with
sh -x scriptname
to better understand what happens.
We have a Wiki page dedicated to Shell batch jobs:
http://grass.gdf-hannover.de/wiki/GRASS_and_Shell
which may also be of help.
On Fri, Aug 18, 2006 at 12:29:42PM +0200, Robert Nuske wrote:
Dear Developers,
cheers,
robert
6.0.2 is okay
with:
grass-dev mailing list
grass-dev@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Markus,
with the help of the wiki page you mentioned, I discovered that batch-grass.sh
is missing at least:
- LD_LIBRARY_PATH
- GIS_LOCK
- cleanup routine
where $GISBASE/lib in the LD_LIBRARY_PATH seems to be vital.
The broken batch-grass.sh is still on this website:
http://grass.itc.it/faq/index.html
It should be stated that the script is not working with newer versions of
GRASS or fixed accordingly.
Since I found batch-grass comfortable for running the same script in different
mapsets over night, I updated it. I attached my version of batch-grass.sh,
which is working with all 6.x versions, in case you want to replace the
broken one.
cheers,
robert
Am Freitag 18 August 2006 13:44 schrieb Markus Neteler:
Robert,
sh -x scriptname
> Dear Developers,
> with whatever cvs version was up-to-date at that time, probably 6.1.
> with the 6.0 version but not with the newer versions.
> do I need to do, to get batch-grass.sh working again.
> cheers,
> robert
> 6.0.2 is okay
> with:
(attachments)
batch_new.sh (2.08 KB)
On Mon, Aug 21, 2006 at 02:30:51PM +0200, Robert Nuske wrote:
Markus,
- LD_LIBRARY_PATH
- GIS_LOCK
- cleanup routine
Yesterday I had already updated the FAQ page accordingly.
broken one.
Thanks, I'll upload the new script.
cheers,
robert
> Robert,
> sh -x scriptname
> Markus
> > Dear Developers,
> > cheers,
> > robert
> > 6.0.2 is okay
> > with:
> > _______________________________________________
