[GRASS-dev] black: Python code formatter (eg PEP8)
Just few more points (not in any particular order):
  • If black is used, all open pull requests, branches etc will need to be rebased. My guess is that it will often be easier to just re-implement instead of solving the conflicts.
  • Unless black is used on releasebranches too, backporting will not be trivial and/or automated.
  • black uses 88 chars as the default line length. For legacy python this is usually enough, but for newer code using type annotations you often want to bump that up to 100 or even 120 chars
  • black formats functions/methods with a lot of arguments in a specific way that may not be to everyone’s liking. E.g.
def foo(aaaaaaaaaaaa, bbbbbbbbbbbb, cccccccccccccccc, ddddddddddddddddddd):
pass
becomes:
def foo(
aaaaaaaaaaaa,
bbbbbbbbbbbb,
cccccccccccccccc,
ddddddddddddddddddd,
pass
bumping up the line length, somewhat’s mitigates this.
  • black is an automated tool. Optimal results are usually achieved by manually adjusting the code and/or writing the code in a way that is compatible with black (i.e. black will not change it). a typical example - and there are more - are double list comprehensions (which IMHV should usually be avoided but that’s not really relevant here). E.g:
words = [word.upper() for sentence in paragraph for word in sentence]
becomes:
words = [
word.upper()
Re-rewriting this as a nested loop is one less line of code, is more readable because it doesn’t change the flow of execution, is more expendable and is obviously more familiar to those who don’t know python that well:
words =
for sentence in paragraph:
for word in sentence:
words.append(word.upper())
For the record, this particular case could be re-written using itertools.chain
from itertools import chain
words = [word.upper() for word in chain(*paragraph)]
  • black doesn’t play too well with inline comments. E.g.
a = [
“a”,
“b”, # noqa
“c”,
will be transformed to:
a = [“a”, “b”, “c”] # noqa
This means that the noqa comment will be applied to all the arguments instead of “b” only.
  • Probably not a huge issue for GRASS, but black does not preserve indentation of comments. So E.g this will become:
class A(object):
def init(self):
self.a = 1
self.b = 2
will become
class A(object):
def init(self):
self.a = 1
self.b = 2
If you want to preserve the indentation you would need to comment out using this:
class A(object):
def init(self):
self.a = 1
self.b = 2
all the best,
P.
