Can you tell me howto use bound_box in python. I am new in grass
developping and i use python. I need to use Vect_get_map_box and
bound_box* type is requiered.
___________________________________________________________________________
Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail et son interface révolutionnaire.
http://fr.mail.yahoo.com
On Sun, May 31, 2009 at 12:45 PM, Danho Fursy Rodelec Neuba
In theory it should be
import os, sys
from grass.lib import grass
from grass.lib import vector as grassvect
grassvect.Vect_get_map_box(map, box)
but I (also) failed to define
box = grassvect.bound_box()
I have added that locally to
swig/python/examples/vectoraccess.py
but I get
File "examples/vectoraccess.py", line 45, in <module>
print 'Map box:', grassvect.Vect_get_map_box(map, box)
TypeError: in method 'Vect_get_map_box', argument 2 of type 'BOUND_BOX *'
Using instead BOUND_BOX, it also fails:
File "examples/vectoraccess.py", line 32, in <module>
box = grassvect.BOUND_BOX()
AttributeError: 'module' object has no attribute 'BOUND_BOX'
@developers:
Looking at the GRASS includes, I see
include/vect/dig_structs.h:#define BOUND_BOX struct bound_box
Is there a strategic advantage to define 'struct bound_box' like this while
for example 'struct Map_info' isn't defined as MAP_INFO in the Vector
libs?
Markus Neteler wrote:
but I get
Right. SWIG only generates wrappers for the "struct bound_box" type,
but requires that you pass a "BOUND_BOX *" to the function.
Like most things which deal with C, it gets confused by preprocessor
macros.
libs?
No. If you really want an alias, use typedef, e.g.:
typedef struct bound_box BOUND_BOX;
But I would prefer to just use "struct bound_box" everywhere to make
it clear that it's a structure.
I intend to commit a fix once the test compilation has completed.
More generally: avoid using the preprocessor unless it's absolutely
essential. Any convenience which it appears to offer is usually
illusory; you get convenience in one aspect, and inconvenience in a
dozen others.
On Mon, Jun 1, 2009 at 6:59 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
but I get
macros.
libs?
typedef struct bound\_box BOUND\_BOX;
Thanks - testing the backport, will submit once SVN wakes up again.
import os, sys
It has been fixed in SVN of 6.4, 6.5 and 7. Now
access to vector boxes is possible.
Here a simple example:
see also swig/python/examples/vectoraccess.py
# vector box tests
c_easting1 = 599505.0
c_northing = 4921010.0
c_easting2 = 4599505.0
print 'Position 1 in box? ', grassvect.Vect_point_in_box(c_easting1,
c_northing, 0, box)
print 'Position 2 in box? ', grassvect.Vect_point_in_box(c_easting2,
c_northing, 0, box)
print 'Vector line 2 in box? ', grassvect.Vect_get_line_box(map, 2, box)
