-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
While compiling qgis, I noticed that GRASS API has been broken:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/include/version.h.in.diff?r1=1.4&r2=1.5
As a result, QGIS can no longer be compiled with GRASS support. Are
these changes really necessary?
All the best.
pc
Paolo Cavallini
http://www.faunalia.it/pc
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGMHK2/NedwLUzIr4RAnkUAKCkat9NHrWXbxNZiACLNSrJuK2giwCfTSlj
Zhfj1q4SIjKkyNADu9oitgE=
=vJFF
-----END PGP SIGNATURE-----
Paolo Cavallini wrote on 04/26/2007 11:36 AM:
Hi all.
All the best.
pc
The question is if the change keeps backwards compatibility for
GDAL, QGIS and other applications which rely on this file.
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
Hash: SHA1
for qgis, it does not
pc
Paolo Cavallini
iD8DBQFGMKtP/NedwLUzIr4RAgA7AJ9I2I3rlB8/x/O0gl0jNT2ZG1vIYQCfZMdV
L34YIu7khLPOuVWbCD9oc/k=
=4QXv
No, the original API was broken; it has now been fixed.
Yes. If they weren't done before 6.3.0 is released, we would be stuck
with the original verion for the lifetime of the 6.3.x. branch.
Since gdal-grass plugin fails to build with 6.3 CVS too, will r.out.gdal in
6.3 CVS work when I build the plugin against 6.2.2 CVS, and keep both 6.2.2
and 6.3 installed?
Maciek
View this message in context: http://www.nabble.com/broken-API-tf3650628.html#a10216768
Sent from the Grass - Dev mailing list archive at Nabble.com.
Maciej Sieczka wrote on 04/27/2007 12:31 PM:
It now compiles again (gdal-grass plugin in the GDAL SVN).
will r.out.gdal in
and 6.3 installed?
No idea...
and 6.3 installed?
In 6.2, r.out.gdal is a script which uses gdal_translate, so it
requires a GRASS-enabled GDAL. In 6.3, r.out.gdal is a C program which
only uses GDAL for the output side, so it doesn't matter whether GDAL
has GRASS support.
So, the 6.3 version of r.out.gdal won't use GDAL's GRASS support
unless you use it to export to GRASS (why would you want to do that?).
Hash: SHA1
Hi all.
https://svn.qgis.org/trac/ticket/712
It has been fixed last night in QGIS SVN HEAD.
You need to fixed GRASS-GDAL-Plugin from GDAL SVN HEAD, too
(for raster support). A new plugin will be released soon:
http://trac.osgeo.org/gdal/ticket/1587
Apparently things are operational again.
Hash: SHA1
Hi all.
Still broken for QGIS 0.8.1 to-be-relased "stable" branch, though.
Maciek
>> Hash: SHA1
>> Hi all.
I have posted this there and re-opened ticket 712.
> >> Hash: SHA1
> >> Hi all.
05/03/07 14:26:22 changed by wonder
* status changed from reopened to closed.
* resolution set to fixed.
Okay, I've ported it to 0.8 branch in r6925.
Also done.
Hash: SHA1
Hi all.
The workaround has now been backported to QGIS 0.8 SVN branch. Thanks
to Martin Dobias.
Maciek
