10 minutes and 36 seconds |
Anna Petrášová |
d.vect: if size_column is used, write -1 to legend; symbol_size will be then used for point legend, see #3125 git-svn-id: https://svn.osgeo.org/grass/grass/trunk@69133 15284696-431f-4ddb-bdfa-cd5b030d7da7 |
System message:
We are seeing build failures due to new sudo-enabled Precise and Trusty images. See more details here. Thank you for your enduring patience.
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI For help please join our IRC channel irc.freenode.net#travis. Choose who receives these build notification emails in your configuration file. |
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
