[GRASS-dev] Broken r.stream.snap?
the module r.stream.snap which has been included now in the main code of GRASS 7 does not produce an output table which is linked to the output vector map.
Can anyone reproduce that behavior? Or is this related to my machine only? I am working with GRASS7.1 svn (rev61250) on Ubuntu. I hope this is only a minor thing to fix. I filed already a bug report (#2362) but maybe someone knows of a work around in the meanwhile?
Best regards,
Johannes
On Mon, Jul 14, 2014 at 12:05 PM, Johannes Radinger
<johannesradinger@gmail.com> wrote:
vector map.
Yes. There is simply no DB code in r.stream.snap...
Hope someone picks up bug report #2362.
