GRASS GIS 7.3.svn r69289 compilation log
Started compilation: Mon Aug 29 03:54:24 2016
Errors in:
/c/msys64/usr/src/grass_trunk/raster/r.in.lidar
/c/msys64/usr/src/grass_trunk/raster3d/r3.in.lidar
/c/msys64/usr/src/grass_trunk/vector/v.out.lidar
/c/msys64/usr/src/grass_trunk/vector/v.in.lidar
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon Aug 29 04:18:03 2016
Errors in:
'make'.
2016-09-09 19:43 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
2016-09-09 7:22 GMT+02:00 Helmut Kudrnovsky <hellik@web.de>:
there is neither 32bit/64bit standalone 7.2/7.3 nor osgeo4w winGRASS
binaries available in the last days.
Any ideas?
hard to say, I cannot even login to the server. Will be able to tell
more later. Martin
wingrass is partly back. I fixed failure on 64bit builds related to
liblas support. There is still remaining issue - automated task
magically fails. So today's build will be online in delay since I
needed to launch the build script manually. Martin
