[GRASS-dev] [bug #2741] (grass) NVIZ: fly through navigation controls broken
this bug's URL: http://intevation.de/rt/webrt?serial_num=2741
Request number 2741 was commented on by 'msieczka' (Maciek Sieczka).
Responding to this message will send mail to the requestor.
      Request Tracker
      rt@intevation.de
Cc: grass-dev@grass.itc.it,m.cuomo@acsys.it
msieczka wrote (Tue, Nov 28 2006 23:26:44):
I need to look into how the xorg.conf's
Option "Emulate3Buttons" "true"
affect this issue (this is the default setting in all Linux distros I ever
tried).
So I finally checked it. Yes, this is the culprit. For the flythrough NVIZ
navigation mouse controls to work correctly one needs to set:
Option "Emulate3Buttons" "false"
in his X server config to prevent X server from interpretting the mouse
left+right buttons as the middle button. "Emulate3Buttons" "true" is often set
by deafult in various GNU/Linux distros. Is there a way for NVIZ to somehow
ignore this?
Maciek
      Request Tracker
      rt@intevation.de
> tried).
ignore this?
No. The only option is to change the NVIZ bindings so that it doesn't
require LMB+RMB to be pressed simultaneously.
Incidentally, this combination is typically impossible with laptops
which use a touchpad instead of a mouse; there's normally a key which
can be pressed to make the touchpad generate RMB events instead of
LMB, but you can't get both simultaneously.
