hamish_nospam@yahoo.com wrote (Fri, Nov 24 2006 03:39:17):
Maciej Sieczka wrote:
g.region ditches_buf
Which one is that? It's not there in the package I sent you.
It is the saved region:
Oh, right. Sorry, my bad. I thought you meant some vector map (I missed the
fact you didn't put "vect=" into your g.region call).
can you isolate the problem with:
clearer: if you can extract it to a few simple areas & export with
v.out.ascii it is easier to follow step by step in the debugger. Also
you can post that to the bug's history and others can try without
needing you to send them the 1mb location download- more data points.
You are right, should have thought of using v.out.ascii for debugging.
maybe it is a FP epsilon problem, which is slightly different
machine to machine + compiler to compiler? e.g. 123.4000000000002 vs
123.4.
Would that mean v.buffer is supposed to work on some Linuces and not
on the other? That would be a nightmare.
I don't know. It is just a guess of why our two systems would be
different. I am testing with a Pent4 32bit debian/stable machine.
Is yours 64bit?
No. 32 bit, Pentium M 750 (Dothan). Ubuntu Dapper 2.6.15-27-686. I'm not using
any optimization at the build time. GCC 4.0.3-1ubuntu5.
v.buffer will try and do the same calculation, but the
computer may give a slightly different results. That will happen with
any 32bit and 64bit system doing FP math, with any program. It would be
a v.buffer bug if e.g. if it tests FP1==FP2 when it should test
"fabs(FP2-FP1) <= EPSILON"
This is propably not the case here. But I have a lead :). Please read at the
bottom.
does "d.what.vect -f" (or without -f check area size) show the original
as a closed area?
Yes:
$ d.vect ditches; d.what.vect -f
map: 'ditches'
mapset: 'vbuffer_bugs'
feature type: Area
area size: 475.449658
Layer: 1
category: 1205
Database connection not defined
Please watch the swf at [3], where I present step-by-step the two runs
of v.buffer on the problematic dataset - before and after the required
"edit", including how the "edit" looks like. I'm just moving vertex of
a topologically clean boundary a bit and snapping it back. Strange...
sorry, I don't have flash installed. But I trust you are honest and we
have tried the same commands
Following your v.out.ascii hint here's what I found out.
Extract the problematic area 1205:
$ v.extract in=ditches out=ditch_1205 type=area list=1205
Buffer it:
$ v.buffer ditch_1205 out=ditch_1205_b1 type=area buffer=1
$ v.buffer ditch_1205 out=ditch_1205_b4 type=area buffer=4
As expected, both outputs are wrong, see [2] and [3], respectively.
Running the ditch_1205 through ascii vector, like:
$ v.out.ascii ditch_1205 form=standard | v.in.ascii format=standard
out=ditch_1205_asciied
doesn't change anything - buffering the ditch_1205_asciied still yields wrong
results, exactly the same as seen on [2] and [3].
However, after "editing" the ditch_1205 in v.digit, like shown on [4],[5],[6],
ie. dissjoining the boundary and snapping the vertex back,
$ g.copy vect=ditch_1205,ditch_1205_edt
$ v.digit ditch_1205_edt #see [4],[5],[6]
buffering this resulting vector yields correct results; see [7],[8], respectively:
$ v.buffer ditch_1205_edt out=ditch_1205_edt_b1 type=area buffer=1
$ v.buffer ditch_1205_edt out=ditch_1205_edt_b4 type=area buffer=4
Now, why does this "touch" of v.digit help? The *only* difference between
ditch_1205 and the "edited" ditch_1205_edt according to v.out.ascii is where
the boundary no #4 is mentioned, see:
$ v.out.ascii ditch_1205 form=standard | awk 'NR>10'
B 4
600727.68682251 5677973.32091602
600739.16582305 5678137.49568095
600736.32863997 5678140.4618269
600730.63832718 5678056.67823368
B 2
600725.02385533 5677974.01131491
C 1 1
600730.04890192 5678035.56666655
1 1205
B 2
compared to:
$ v.out.ascii ditch_1205_edt form=standard | awk 'NR>10'
B 2
C 1 1
1 1205
B 2
B 4
Note there is no single difference between the 2 *besides* the order in which
boundaries are listed. Somehow, the ditch_1205 having boundary #4 listed as
first is wrong for v.buffer (on my machine), while the ditch_1205_edt, having
the same boundary listed as the last one, is OK.
Does this finding help?
Maciek
[0]http://kufaya.googlepages.com/v.bufferbug%232765
[1]http://kufaya.googlepages.com/ditch_1205.png
[2]http://kufaya.googlepages.com/ditch_1205_b1.png
[3]http://kufaya.googlepages.com/ditch_1205_b4.png
[4]http://kufaya.googlepages.com/ditch_1205_edt1.png
[5]http://kufaya.googlepages.com/ditch_1205_edt2.png
[6]http://kufaya.googlepages.com/ditch_1205_edt3.png
[7]http://kufaya.googlepages.com/ditch_1205_edt_b1.png
[8]http://kufaya.googlepages.com/ditch_1205_edt_b4.png
