this bug's URL: http://intevation.de/rt/webrt?serial_num=2793
Request number 2793 was commented on by 'msieczka' (Maciek Sieczka).
Responding to this message will send mail to the requestor.
Request Tracker
rt@intevation.de
Cc: grass-dev@grass.itc.it
Is there a chance this bug will be fixed for 6.2? v.segment's side offset is a
highly appreciated feature in a script I'm currently developing. I'm working
the bug around by creating parallel lines (v.parallel) and running v.segment
on them, but it's a bit cumbersome and requires intermediate temporary vectors
which I could avoid if v.sgemnt wasn't buggy.
msieczka wrote (Mon, Oct 9 2006 01:10:36):
I have used v.segment in the last days and I'm sure there is a bug in
the side offset, at least for point mode. The bug is that the offset
doesn't work, it is always 0.Folks have been reporting this:
http://grass.itc.it/pipermail/grassuser/2005-December/031522.html
http://www.nabble.com/-GRASS-user--HEC-RAS-tf2066275.html#a5691777
http://www.nabble.com/-GRASS-user--v.segment---how-to-use-orthogonal-offset--tf2065644.html#a5691131
