[GRASS-dev] [bug #2794] (grass) wish window mouse wheel and TAB
Is done for gis.m.
In d.m wheel doesn't work (CVS 2006.06.19), although about a month ago it used
to output an error if tried (http://intevation.de/rt/webrt?serial_num=4466).
Was it an unseccussfell, then reverted, attempt to support wheel in d.m? Any
chances wheel will work in d.m?
File selection dialogs support wheel nicely.
"Options" panel in modules is quite OK, besides modules like v.to.db, where
scrolling parameters' selection lists (e.g. v.to.db's "Value to upload", i.e.
"option=" parameter) causes the whole panel to be scrolled, instead of the
parameters list alone.
"Output" panel is mostly scrollable, besides when mouse pointer hovers over
the grey belt with icons and command syntax - no scrolling then. If there is
not much space between subsequent grey belts, the panel is hardly scrollable
at all.
The TAB key circulates through the "Options" panel OK, only it shouldn't
bother stopping at the top icon (strange, why is it pressable?) next to module
description and at the bottom icon (the copy-command one).
Nice progress but still stuff missing. What are the plans?
Maciek
See below
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
From: Maciek Sieczka via RT <grass-bugs@intevation.de>
Reply-To: Maciek Sieczka via RT <grass-bugs@intevation.de>
Date: Thu, 22 Jun 2006 21:14:15 +0200 (CEST)
To: <jidanni@jidanni.org>
Cc: <grass-dev@grass.itc.it>, <michael.barton@asu.edu>,
<cedricgrass@shockfamily.net>
Subject: [bug #2794] (grass) wish window mouse wheel and TAB
Is done for gis.m.
Cedric added scroll wheel support in gis.m. I am not supporting d.m for any
more upgrades--just bug fixes. If someone else wants to add it, that's fine.
at all.
Cedric is working on the two above.
If this is layer options, I'll look at it and see if I can change this.
Except for above (and interactive x11 dependencies in a few C-Modules), what
is still missing?
Maciek
On Fri, 23 Jun 2006 11:10:29 -0700
Michael Barton <michael.barton@asu.edu> wrote:
See below
Michael
phone: 480-965-6213
fax: 480-965-7671
> Is done for gis.m.
> ago it used
> d.m? Any
for any more upgrades--just bug fixes. If someone else wants to add
it, that's fine.
Oh, so the http://intevation.de/rt/webrt?serial_num=4466 wasn't a sign
of trying to implement wheel in d.m. Do you know then why dis that
error appear first and then dissapeared after a month, when I checked
for it again?
> v.to.db, where
> upload", i.e.
> of the
> hovers over
> there is
> scrollable
> at all.
Cool. So that's why we haven't heard from him lately - hidden and
coding! Good news. Or maybe just tired with fame :)?
> shouldn't
> next to module
this.
Nice, thanks.
C-Modules), what is still missing?
d.nviz doesn't start from d.m's icon, only prints "ERROR: Required
parameter <input> not set: (Name of existing raster map)." and help to
the terminal.
http://intevation.de/rt/webrt?serial_num=4138
There are also many bug reports with "gis.m" and "d.m" in the title
still open. Some of them seem still valid I know, some I don't. Some
where never answered by responsible devs. Maybe you and Cedric might be
the best people to know which to close or how to comment them?
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
