[GRASS-dev] [bug #3069] (grass) r.mapcalc - warning/errorr amibiguity
Maciek Sieczka wrote (Fri, Mar 4 2005 18:10:55):
GRASS 6.0.cvs:~ > r.mapcalc 'lake=kpn65'
WARNING: 'cell/kpn65' was found in more mapsets (also found in topo).
ERROR: 'cell/kpn65' was found in more mapsets (also found in topo).
This is still a bug. Not serious at all for a Grass whiz, but 6.1 newbies will
be scared. I think WARNING will be enough (at least not both warning and error).
Maciek
newbies will be scared. I think WARNING will be enough (at least not
g.mapsets includes "topo" as a secondary mapset in the path?
Hamish
Hamish napisa?(a):
I don't have this particular location at hand now, so I'll use another
one, OK? I hope the commands below will explain enough:
$ g.mapsets -p
nic PERMANENT
$ g.gisenv
GISDBASE=/home/grassdata
LOCATION_NAME=xy
MAPSET=nic
GRASS_GUI=text
$ g.list rast
raster files available in mapset nic:
map
raster files available in mapset PERMANENT:
map
$ r.mapcalc 'map2=map'
WARNING: 'cell/map' was found in more mapsets (also found in nic).
ERROR: 'cell/map' was found in more mapsets (also found in nic).
$ g.list rast
map
map
And so the 'map2' is not created as you can see...
I though about this once more, and I'm wondering:
Should only error be issued and information that implicit '@mapset' has
to be put for r.mapcalc to work in case of identical names?
Or should r.mapcalc default to 'map' in the current mapset, issuing a
warning only that an identical raster exists in other mapset/s?
The firt approach looks more user-error proof (paranoid?), the latter
will be more convenient in daily use.
How do other modules handle identical names in different mapsets? (I
guess they default to current mapset and don't even care for other
mapsets, unless implicit @mapset is used...).
Maciek
