r.mapcalc still prints this double information in case 2 same called
rasters exit within the accesible mapsets, eg.:
WARNING: 'cell/map' was found in more mapsets (also found in nic).
ERROR: 'cell/map' was found in more mapsets (also found in nic).
Moreover, in such case r.mapcalc exits with status 1. Could it be bad
for scripts?
(not commenting on the bug, just the symptoms)
exit code of 1 is appropriate if the module exited with an ERROR.
If the system found an ambiguity, it is better to stop with an error
than pick the wrong map and potentially mess up the data without the
user noticing.
r.mapcalc still prints this double information in case 2 same called rasters
r.mapcalc uses G_set_error_routine() to install an error handler; the
error handler calls G_fatal_error() regardless of the value of the
"fatal" argument.
I'll fix this.
Moreover, in such case r.mapcalc exits with status 1. Could it be bad for scripts?
As I've mentioned before somewhere, I find this message a bit confusing, especially the "also found in" which normally gives me the mapset I am in and want to use the map of (at least it does so when in mapset user1 of spearfish working on a local copy of a map which is also in PERMANENT).
Couldn't this be changed so that it mentions the _other_ mapsets the map is in, and maybe mention which map is used by default (I know that in this case it stops with an error, but many other modules just emit this as a warning, leaving the user uninformed of which map was used) ?
I've changed it so that it identifies all of the mapsets involved,
e.g.:
$ r.resample in=fields out=fields
Creating support files for fields...
creating new cats file...
$ r.mapcalc foo = fields
WARNING: 'cell/fields' was found in more mapsets (also found in PERMANENT).
WARNING: using 'fields@glynn'.
e.g.:
