[GRASS-dev] [bug #4141] (grass) more sql statements for db.execute
guest wrote (Mon, Mar 6 2006 17:36:36):
maybe this sql statement support could be added to db.execute as well:
this doesn't work:
echo "SELECT gkz,name,bev0100,bevm0100,bevw0100 FROM stand,testregion WHERE
plz = gkz" | db.execute
this is fine:
plz = gkz" | psql -U dassau ifak
By accident I have laerned today that db.execute is not supposed to support
SELECT query. We have db.select for that. In that case, do we call the case
closed?
Maciek
> this doesn't work:
> this is fine:
closed?
Maciek
(I didn't follow the entire thread, so my comments may be useless.
YMMV. :slight_smile:
Personally, I'd like db.select merged into db.execute. I don't use the
db.* commands daily and I've fallen into the above case before.
However, I quickly remember the more appropriate usage.
OTOH, db.execute isn't supposed to return and resulting set, which is
why db.select exists (to my knowledge). I've committed a change in CVS
to db.execute.html noting this and suggests using db.select.
I would consider this closed.
73, de Brad KB8UYR/6 <rez touchofmadness com>
> support SELECT query. We have db.select for that. In that case, do we
> call the case closed?
IIRC in an old post Radim explained why that must be, but can't find it
now.
still outstanding: db.execute needs to throw an error- not segfault -when
passed SELECT.
Hamish
