This is a d.rast problem rather than a d.m problem.
Why does d.m crash then instead of issuing a warning and displaying the map
from current mapset anyway, like d.rast does?
You can avoid it by specifying map@$MAPSET.
Following d.rast behaviour as described above would be best, if possible. If
not, maybe d.m could do that for the user: add "@mapset" suffix to the map
name after the map is selected from the list or, if map name is typed in
manually in d.m, force the current mapset?.
Maciek
