Radim Blazek wrote:
> > Note that it is also possible to set region with GRASS_REGION
> > environment variable.
> I wasn't aware of that feature. That would be simpler for running
> commands with a specific region from gis.m.
> However, I don't think that the way it is currently implementated is a
> good idea, as it overrides all saved regions as well as the current
> region. I would suggest moving it to G_get_window(), so that programs
> which use G__get_window() to read a specific named region aren't
> affected.
Of course, I moved it to G_get_window(). But then g.region -p
prints WIND file, not GRASS_REGION variable, I am not sure
what it should. Probably it should print GRASS_REGION?
I would say so.
g.region doesn't use G_get_window() to get the current region, but
uses:
if (G__get_window (&window, "", "WIND", G_mapset()) != NULL)
G_get_default_window (&window);
G_put_window (&window);
The logic here is that if the WIND file is invalid, the only way to
set it is to run g.region, so so g.region can't just just call
G_get_window() (which will generate a fatal error if the WIND file is
invalid).
Note that it does this before calling G_parser(), so that it can use
window.proj in the option definitions.
After G_parser() returns, it replaces the region with the default
region if the -d flag is used, or with the named region if region= is
used. Otherwise, the previously-obtained region is retained and
modified according to the other options.
There are a few possible solutions.
One is to obtain the initial region using G_get_default_window().
After G_parser() returns, if the -d flag isn't given, it would use
G_get_window() to replace this with the current region. That would
allow the use of "g.region -d" to fix a missing/invalid WIND file,
while causing GRASS_REGION and WIND_OVERRIDE to work normally.
The other is to explicitly test for GRASS_REGION and/or WIND_OVERRIDE
in g.region.
> I've recently fixed a small number of modules which gratuitously used
> G__get_window(..., "WIND") to get the current region.
> [Most of these did so in order to handle the case where the current
> region was undefined, and use the default region instead. If that's
> considered a good idea, it should be done in G_get_window() so that it
> works for every module, not by a handful of specific modules.]
I think that undefined region is error and it should result in
G_fatal_error().
Agreed.
But even if the fault-tolerant behaviour was desirable, it should be
implemented in the libraries, rather than a handful of modules doing
it themselves.
> For future development, I'm wondering if it would be a good idea to
> replace the WIND file with a GRASS variable (e.g. REGION) using the
> same syntax as GRASS_REGION.
Do you mean GRASS mapset variable (in VAR)?
Well, I meant that G_get_window() would become use G_getenv("REGION")
rather than G__get_window(..., "WIND"). It wouldn't really matter if
it was a mapset or GISRC variable; the main point was not to store
state in a form which can only have a single instance. Actually, the
same issue applies to the VAR file; what uses that? Just QGIS?
If all "session state" goes into $GISRC, you can just create a new
$GISRC file for each operation, without worrying about conflicts
(providing that the operations only read the data; supporting
concurrent modification is a long way off).
I am using WIND as test for mapset in QGIS, exists another way
to test if a directory in location is a mapset?
You could test whether ../PERMANENT/DEFAULT_WIND exists. Or even just
whether ../PERMANENT exists.
