Subject: gis.m/r.what incompatible: quering rasters outside current region doesn't work
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: 2006-05-08
Quering rasters in gis.m doesn't work properly because r.what depends on current region settings, which gis.m ignores. False nulls are returned as an efect.
Can r.what be fixed to query raster outside the current region?
Maciek
Wrong solution. gis.m needs to set WIND_OVERRIDE correctly before
calling r.what.
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4428
> region doesn't work
calling r.what.
> > region doesn't work
> calling r.what.
First and foremost, the user should not set WIND_OVERRIDE in a GRASS
session. It's meant to be set locally for specific commands. It's
debatable whether it belongs in the users' manual.
It causes programs to use the specified named region (created with
e.g. "g.region save=...") to be used as the current region, instead of
the region from the WIND file.
This allows programs such as gis.m to run external commands on an
alternate region without having to modify the WIND file then change it
back afterwards.
