[GRASS-dev] [bug #4450] (grass) g.remove vect: empty dirs in the $MAPSET/.tmp/$HOSTNAME left
this bug's URL: http://intevation.de/rt/webrt?serial_num=4450
Subject: g.remove vect: empty dirs in the $MAPSET/.tmp/$HOSTNAME left
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: 2006-05-08
For each vector file it removes, g.remove leaves 1 empty, redundant directory in the $MAPSET/.tmp/$HOSTNAME. These directories are not removed after quiting Grass either.
$ ls -R /home/grassdata/caves_utm33/melio2/.tmp/$HOSTNAME
/home/grassdata/caves_utm33/melio2/.tmp/quercus:
16491.0
/home/grassdata/caves_utm33/melio2/.tmp/quercus/16491.0:
Maciek
