this bug's URL: http://intevation.de/rt/webrt?serial_num=4469
Subject: g.region: nsres & ewres are rounded differently
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: 2006-05-18
Hi
nsres & ewres are rounded differently when setting res to something near the decimal places limit.
In [1] both nsres & ewres are rounded-down to 1.12345678 when requested res=1.123456784. That's OK.
But in [2], when requested one decimal point higher res=1.123456785, nsres is rounded-up to 1.12345679 while ewres is rounded-down to 1.12345678.
Moreover, next g.region run [3] with settings identical like in [2] results in ewres=nsres=1.12345678, and, naturaly, different region extent.
Is this all OK? I thought each single, identical g.region run should result in the exactly same region settings.
[1]
$ g.region res=1.123456784 -ap
projection: 1 (UTM)
zone: 33
datum: wgs84
ellipsoid: wgs84
north: 5687680.84554222
south: 5673969.0554935
west: 593389.65108669
east: 603210.91029242
nsres: 1.12345678
ewres: 1.12345678
rows: 12205
cols: 8742
[2]
$ g.region res=1.123456785 -ap
projection: 1 (UTM)
zone: 33
datum: wgs84
ellipsoid: wgs84
north: 5687680.85060488
south: 5673967.93708717
west: 593388.52815808
east: 603210.91082934
nsres: 1.12345678
ewres: 1.12345679
rows: 12206
cols: 8743
[3]
projection: 1 (UTM)
zone: 33
datum: wgs84
ellipsoid: wgs84
south: 5673966.81363039
west: 593387.4047013
east: 603212.03428612
nsres: 1.12345679
ewres: 1.12345679
rows: 12207
cols: 8745
Maciek
