paul-grass@stjohnspoint.co.uk wrote (Mon, Jul 24 2006 10:32:58):
Ah you must be using the new "alternative" build system then - Hamish's
instructions were for the old system. You need to find the script gmake55
which will be in the root of your build directory (this directory should
be outside of the source tree structure) and run it from there as follows:./gmake55 src/imagery/i.cca
This method failed too. Finally I found gmake55 executable in
bin.i686-pc-linux-gnu dir, copied it to a dir included in my PATH and it
works. Details:
$ gmake55 src/imagery/i.cca/
SRC = /home/shoofi/src/straight/grass/src
CMD = /home/shoofi/src/straight/grass/src/CMD
UNUSED = /home/shoofi/src/straight/grass/unused
HEADER = head.i686-pc-linux-gnu
ARCH = i686-pc-linux-gnu
GISBASE = /home/shoofi/src/straight/grass/dist.i686-pc-linux-gnu
VERSION = 5.5-cvs 2004
/home/shoofi/src/straight/grass/src/imagery/i.cca
make -f OBJ.i686-pc-linux-gnu/make.rules
/home/shoofi/bin/gmake55 -all
/home/shoofi/src/straight/grass/src/imagery/i.cca/cmd
make[1]: Entering directory
`/home/shoofi/src/straight/grass/src/imagery/i.cca/cmd'
gcc -I/home/shoofi/src/straight/grass/src/include -g -O2 -c matrix.c -o
OBJ.i686-pc-linux-gnu/matrix.o
In file included from matrix.c:3:
globals.h:12: error: array type has incomplete element type
make[1]: *** [OBJ.i686-pc-linux-gnu/matrix.o] Error 1
make[1]: Leaving directory `/home/shoofi/src/straight/grass/src/imagery/i.cca/cmd'
make: *** [all] Error 1
$ gmake55 src/raster/r.grow2
/home/shoofi/src/straight/grass/src/raster/r.grow2
gcc -I/home/shoofi/src/straight/grass/src/include -g -O2 -c main.c -o
OBJ.i686-pc-linux-gnu/main.o
main.c:13: error: static declaration of 'abs' follows non-static declaration
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
$ gmake55 src/sites/s.in.ascii
/home/shoofi/src/straight/grass/src/sites/s.in.ascii
main.c: In function 'G_site_put_new':
main.c:184: error: invalid storage class for function 'format_double'
$ gmake55 src.contrib/SDTS
/home/shoofi/src/straight/grass/src.contrib/SDTS
/home/shoofi/bin/gmake55 ./libes/fips123
/home/shoofi/src/straight/grass/src.contrib/SDTS/libes/fips123
`/home/shoofi/src/straight/grass/src.contrib/SDTS/libes/fips123'
make[1]: Nothing to be done for `all'.
/home/shoofi/bin/gmake55 ./mapdev/v.out.sdts
/home/shoofi/src/straight/grass/src.contrib/SDTS/mapdev/v.out.sdts
`/home/shoofi/src/straight/grass/src.contrib/SDTS/mapdev/v.out.sdts'
-I../../libes/fips123/f123inc -g -O2 -c v.out.sdts.c -o
OBJ.i686-pc-linux-gnu/v.out.sdts.o
In file included from v.out.sdts.c:29:
externs.h:29: error: array type has incomplete element type
externs.h:30: error: array type has incomplete element type
externs.h:31: error: array type has incomplete element type
externs.h:32: error: array type has incomplete element type
externs.h:33: error: array type has incomplete element type
make[1]: *** [OBJ.i686-pc-linux-gnu/v.out.sdts.o] Error 1
make: *** [all] Error 2
$ gmake55 src.garden/grass.postgresql
/home/shoofi/src/straight/grass/src.garden/grass.postgresql
/home/shoofi/bin/gmake55 d.rast.pg
/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.rast.pg
`/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.rast.pg'
make[1]:
`/home/shoofi/src/straight/grass/dist.i686-pc-linux-gnu/etc/bin/cmd/d.rast.pg'
is up to date.
/home/shoofi/bin/gmake55 d.site.pg
/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.site.pg
`/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.site.pg'
make[1]:
`/home/shoofi/src/straight/grass/dist.i686-pc-linux-gnu/etc/bin/cmd/d.site.pg'
is up to date.
/home/shoofi/bin/gmake55 d.vect.pg
/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.vect.pg
`/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.vect.pg'
make[1]:
`/home/shoofi/src/straight/grass/dist.i686-pc-linux-gnu/etc/bin/cmd/d.vect.pg'
is up to date.
/home/shoofi/bin/gmake55 d.what.s.pg
/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.what.s.pg
`/home/shoofi/src/straight/grass/src.garden/grass.postgresql/d.what.s.pg'
gcc -I/home/shoofi/src/straight/grass/src/include -I/usr/include/postgresql/
-Wall -DPACKAGE=\""d.what.s.pg"\" -g -O2 -c runPg.c -o
OBJ.i686-pc-linux-gnu/runPg.o
runPg.c: In function 'runPg':
runPg.c:122: error: invalid lvalue in assignment
make[1]: *** [OBJ.i686-pc-linux-gnu/runPg.o] Error 1
$ gmake55 src.contrib/DUKE/r.terraflow
/home/shoofi/src/straight/grass/src.contrib/DUKE/r.terraflow
/home/shoofi/bin/gmake55 IOStream/lib
/home/shoofi/src/straight/grass/src.contrib/DUKE/r.terraflow/IOStream/lib
`/home/shoofi/src/straight/grass/src.contrib/DUKE/r.terraflow/IOStream/lib'
c++ -I/home/shoofi/src/straight/grass/src/include -I../include -g -O2 -c
minmaxheap_test.cc -o OBJ.i686-pc-linux-gnu/minmaxheap_test.o
../include/replacementHeap.h:155: error: invalid use of constructor as a template
../include/replacementHeap.h:155: note: use 'ReplacementHeap<T,
Compare>::ReplacementHeap' instead of 'ReplacementHeap<T, Compare>::class
ReplacementHeap<T, Compare>' to name the constructor in a qualified name
../include/replacementHeapBlock.h:161: error: invalid use of constructor as a
template
../include/replacementHeapBlock.h:161: note: use 'ReplacementHeapBlock<T,
Compare>::ReplacementHeapBlock' instead of 'ReplacementHeapBlock<T,
Compare>::class ReplacementHeapBlock<T, Compare>' to name the constructor in a
qualified name
make[1]: *** [OBJ.i686-pc-linux-gnu/minmaxheap_test.o] Error 1
make: *** [IOStream/lib/LIB.i686-pc-linux-gnu/libiostream.a] Error 2
Maciek
