Hamish wrote (Mon, Jul 10 2006 11:24:12):
The correct solution IMO is to relegate overly verbose messages to
G_debug(1,) or a -v verbose flag, and continue to send warnings and
errors to stderr.> > Patch complete. 2 files patched.
in effect G_done_msg().
> > Intersections at borders will have to be snapped.
> > Lines common between files will have to be edited.
> > The header information also may have to be edited.These 3 are somewhere between needing Warnings and boldface type in the
help page. (hence G_message())The question might be reduced to "where to send G_message()?" ?
Anywhere but stdout, I think.
Example reason: I don't want somebody using my v.flip (a script that calls
v.patch, among the others) to be confused with v.patch information that:
# Intersections at borders will have to be snapped.
# Lines common between files will have to be edited.
# The header information also may have to be edited.
Because I have taken care of this for the user, knowing what the input for
v.patch is and using 'v.clean tool=snap' as needed. That information above is
simply wrong and confusing the user, when v.patch is a script component.
Maciek
