The bug still bites (CVS today).
Maciek
Maciek
I hope the attached patch will fix it...
Best, Martin
2006/7/10, Maciek Sieczka via RT <grass-bugs@intevation.de>:
Maciek
grass-dev mailing list
grass-dev@grass.itc.it
copy_tab.diff.gz (755 Bytes)
Martin Landa napisa³(a):
Nice! Will try that (propably not today/tomorrow though).
Maciek
Maciej Sieczka napisa³(a):
OK, had some time now.
The patch works against current CVS. Grass built and installed OK.
db.copy doesn't segfault when trying to ovewrite an existing table and
works properly when copying table under unique name. All seems fine.
Tested only using DBF though.
Could someone apply Martin's patch?
Thanks!
Maciek
Patch applied to both HEAD and 6.1.0-Branch.
thanks
On Mon, Jul 10, 2006 at 01:50:40PM +0200, Martin Landa wrote:
Best, Martin
>Maciek
>_______________________________________________
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
