[GRASS-dev] [bug #4532] (grass) gis.m: missing buttons in GUI
the simple problem is:
#% gisprompt: file,file,file
which should be
#% gisprompt: old_file,file,file
or
#% gisprompt: new_file,file,file
repectively.
A couple of scripts are affected:
find . -type f -name "*" -exec grep -l ": file,file,file" {} \;
./gui/tcltk/d.m/script/r.reclass.file
./gui/tcltk/d.m/script/r.recode.file
./gui/tcltk/d.m/script/v.in.asciipoints
./gui/tcltk/gis.m/script/r.reclass.file
./gui/tcltk/gis.m/script/r.recode.file
./gui/tcltk/gis.m/script/v.in.asciipoints
Due to power problems today in IRST I cannot submit fixes.
I didn't realize that these were in the shell scripts. I've fixed this and
committed it to the cvs. When did it change from file,file,file
(file,file,file used to work) and what's the difference between old_file and
new_file?
You guys are enjoying weather almost as warm as ours here. But not quite.
The current temperature at 3pm is 46C/115F.
...and it doesn't matter if it's a "dry heat" or not. It's a HOT heat.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
From: Markus Neteler via RT <grass-bugs@intevation.de>
Reply-To: Markus Neteler via RT <grass-bugs@intevation.de>
Date: Fri, 21 Jul 2006 13:45:24 +0200 (CEST)
To: <giorgio.agugiaro@unipd.it>
Cc: <grass-dev@grass.itc.it>
Subject: [GRASS-dev] [bug #4532] (grass) gis.m: missing buttons in GUI
which should be
or
repectively.
new_file?
Old file must exist, new file shouldn't exist unless overwrite is
enabled.
"Enjoying" isn't the term I would use.
quite. The current temperature at 3pm is 46C/115F.
here it's 2-6deg C. But it's a "wet" cold.
Hamish
