this bug's URL: http://intevation.de/rt/webrt?serial_num=4542
Subject: r.in.gdal import south utm projected gtiff as negative zone
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
GRASS Version: 6.1
r.in.gdal import south utm projected gtiff as negative zone. But in grass, region utm zones south of equator not is negative in a newly created location (examples below)
<<PROJ_INFO>>
proj: utm
ellps: SAD-69
a: 6378160.0000000000
es: 0.0066945419
f: 298.2500000000
zone: 22
south: defined
<<cellhd>>
proj: 1
zone: -22
north: 6475848.30684486
south: 6256125
east: 426355.92252066
west: 254360
cols: 5733
rows: 7324
e-w resol: 30.00103306
n-s resol: 30.00045151
format: 1
compressed: 1
When 'g.region -d' is used, the raster imported with r.in.gdal not is visible. The only way to work with it is using g.region 'raster=imported_gtiff'.
To fix the imported gtiff I edit the cellhd file changing -22 to 22, then all is working fine.
This bug not is specific to grass 6 version, is the same for the version 5.
GRASS Version: 6.1
It should be (in the WIND file). And it is in the example you give below! How exactly did you set up the newly created location (which command etc?)
<<PROJ_INFO>>
proj: utm
ellps: SAD-69
es: 0.0066945419
f: 298.2500000000
zone: 22
south: defined
<<cellhd>>
proj: 1
zone: -22
south: 6256125
west: 254360
cols: 5733
rows: 7324
format: 1
compressed: 1
grass-dev mailing list
grass-dev@grass.itc.it
