[GRASS-dev] [bug #4546] (grass) r.sim.water segmentation fault
this bug's URL: http://intevation.de/rt/webrt?serial_num=4546
Subject: r.sim.water segmentation fault
Platform: GNU/Linux/x86_64
grass obtained from: Trento Italy site
GRASS Version: grass-6.1.cvs_src_snapshot_2006_06_03
when running r.sim.water by:
GRASS 6.1.cvs (spearfish60):~ > r.sim.water elevin=elevation.10m
dxin=elevation.10m_dx dyin=elevation.10m_dy rain=elevation.10m_rain
manin=elevation.10m_manin infil=elevation.10m_infil depth=elevation.10m_depth
disch=elevation.10m_disch
it stops with output:
Authors: original version L.Mitas, H.Mitasova
         GRASS implementation J. Hofierka
see references in manual page or at:
http://www2.gis.uiuc.edu:2280/modviz/papers/listsj.html
Running MAY 10 version
Segmentation fault
This applies to many 6.x versions (including stable) and also to 32bit
installations (including precompiled ones).
The input maps "rain", "manin" and "infil" have been created artificially as
constant fields by the following script:
#!/bin/sh
dem=elevation.10m
g.region rast=${dem}
r.slope.aspect --o elevation=$dem dx=${dem}_dx dy=${dem}_dy
r.mapcalc "${dem}_rain=if(${dem},0.0001,null())"
r.mapcalc "${dem}_manin=if(${dem},0.04,null())"
r.mapcalc "${dem}_infil=if(${dem},0.9,null())"
echo r.sim.water elevin=${dem} dxin=${dem}_dx dyin=${dem}_dy \
rain=${dem}_rain manin=${dem}_manin infil=${dem}_infil \
depth=${dem}_depth disch=${dem}_disch
Many thanks for looking at it,
Andreas
try with today's CVS -- Glynn fixed the startup problem yesterday.
cd raster/simwe/
cvs update
make
Hamish
I doubt that's relevant here.
My fix simply removed a "banner" which was being printed even when the
--tcltk switch was used, thus interfering with gis.m.
