this bug's URL: http://intevation.de/rt/webrt?serial_num=4555
Subject: 3D settings cause error in g.region
Platform: Mac OSX
grass obtained from: Mirror of Trento site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.1 cvs 27-May-06
If you try to set 3D settings (resolution, top/bottom) using g.region, it produces an error that depth is 0. Then it is no longer possible to run g.region on the WIND file. It is possible to manually fix WIND with a text editor, but g.region is problematic.
