[GRASS-dev] [bug #4555] (grass) 3D settings cause error in g.region
michael.barton@asu.edu wrote (Fri, Jun 16 2006 09:02:54):
$ g.region res3=30
$ g.region -p
ERROR: region for current mapset is invalid
       line 15: <depths: 0>
       run "g.region"
Michael,
I can't reproduce the error. Can you confirm so I close it?
Maciek
Sorry, but I don't understand the error.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
From: Maciek Sieczka via RT <grass-bugs@intevation.de>
Reply-To: Maciek Sieczka via RT <grass-bugs@intevation.de>
Date: Mon, 25 Sep 2006 19:54:16 +0200 (CEST)
To: <michael.barton@asu.edu>
Cc: <grass-dev@grass.itc.it>
Subject: [bug #4555] (grass) 3D settings cause error in g.region
$ g.region res3=30
$ g.region -p
       run "g.region"
Michael,
Maciek
But it's your own report :).
Maciek
not sure, this bug should be fixed..., see [1]
Martin
[1] http://grass.itc.it/pipermail/grass-dev/2006-August/025040.html
2006/9/25, Maciej Sieczka <tutey@o2.pl>:
Maciek
grass-dev mailing list
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Can you send me the entire report so I know what it is?
Thanks
Michael
phone: 480-965-6213
fax: 480-965-7671
$ g.region res3=30
$ g.region -p
       run "g.region"
Michael,
Maciek
This is bug #4555 in Grass BT:
http://intevation.de/rt/webrt?serial_num=4555
Maciek
As far as I know, this still exists. I can better localize the problem now,
however. If you set the 3D xy resolution, g.region will no longer recognize
the WIND file and you're stuck.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Mon, 25 Sep 2006 21:24:18 +0200
To: Michael Barton <michael.barton@asu.edu>
Subject: Re: [GRASS-dev] Re: [bug #4555] (grass) 3D settings cause error in
g.region
Maciek
