this bug's URL: http://intevation.de/rt/webrt?serial_num=4556
Subject: NVIZ does not display vector maps at startup
Platform: other
grass obtained from: CVS
GRASS Version: CVS checked out at 20060607
Running "nviz raster vect=vect" does not display "vect" map at startup. The vector map shows up only after refreshing the display panel. It looks like the startup procedure uses Nquick_draw which is used when dragging mouse to change positions.
