[GRASS-dev] [bug #4628] (grass) r.out.tiff: check for .tif.tif
this bug's URL: http://intevation.de/rt/webrt?serial_num=4628
Subject: r.out.tiff: check for .tif.tif
r.out.tiff automatically appends a ".tif" to the end of the output filename.
It should check to see if the string ends in upper/lower case .tif or .tiff
before doing this. A lot of folks assume filename extensions will be added
when needed, so I think we should continue to append.
probably r.out.png and friends as well.
anyone have a simple C replacement for `basename $file .tif`?
thanks,
Hamish
Sounds like it would be useful as a library function. I wrote the following which seems to work, but could do with more testing:
  * \brief Checks if a filename matches a certain file extension
  * (case insensitive) and if so, truncates the string to the
  * base file name (cf. basename Unix command)
  * Truncates filename to the base part (before the last .)
  * if it matches the extension, otherwise leaves it unchanged.
  * \param filename String containing filename
  * \param ext String containing extension to look for (case
  * insensitive and as long as needs to be, e.g. tif will
  * match .tif and .tiff, sh will match .shp and .shx, htm will
  * match .htm and .html)
  * \return Pointer to filename
char * G_basename(char *filename, char *desired_ext)
     /* Find the last . in the filename */
     char *dot = strrchr(filename, '.');
     /* Check there is a dot and its not the last character
      * in the string, i.e. there is an extension */
     if(dot && ((dot - filename) < strlen(filename)) )
         char *ext = dot + 1;
         /* if the extension matches (case insensitive)
          * then truncate the filename to the basename */
         if( strncasecmp(ext, desired_ext, strlen(desired_ext)) == 0 )
             *dot = '\0';
     return filename;
H:
P:
Is strncasecmp() portable? man page says "only" BSD 4.4 compliant.
Is it better to use G_tolcase() or G_str_to_lower() first? [I just
noticed those were duplicates. We should consolidate. G_str_to_lower()
is only 2 months old so the obvious choice for removal, but it does
have a better name.]
lib/gis/mapcase.c
lib/gis/strings.c
oh, I see in lib/gis/strings.c we have a G_strcasecmp().
We still should merge G_tolcase() and G_str_to_lower() though.
I see lib/gis/mapcase.c defines tolower() and toupper(). As those are
both standard ANSI C fns, they are redundant and should be removed?
Hamish
On Tue, 2006-06-20 at 12:18 +1200, Hamish wrote:
H:
P:
Yes, it's BSD and not to our definition of portable. Please use
G_strcasecmp().
lib/gis/mapcase.c
lib/gis/strings.c
:slight_smile:
Yeah, it appears that G_to[u|l]case() are redundant. swig uses
G_tolcase(), but I don't see why it couldn't be replaced with
G_str_to_lower().
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
H:
P:
G_strcasecmp().
Hmmm but it needs to be strncasecmp so "tif" will also match "tiff" etc. I guess I could implement it as a for loop matching character by character. Will change that.
> G_strcasecmp().
I can add G_strncasecmp() if it's absolutely necessary (and nobody
objects).
objects).
Well, I have put in a portable version (into basename.c) now and it works so OK for now I think. But if we come across somewhere else that it's needed then would be worthwhile.
Paul
