[GRASS-dev] [bug #4725] (grass) nviz crashed while volume visualisation
[ https://intevation.de/rt/webrt?serial_num=4725 ]
"nviz volume=map3d" segfaults.. see bug report for spearfish example.
I've traced it back to incorrect mode in nviz/src/volume.c
slice_get_drawmode()
mode=1969841253 (or so)
when it should be like DM_GOURAUD=256 or DM_FLAT=512
actual segfault seems to happen after slice_get_drawmode()'s
return (TCL_ERROR);
called from scripts/panel_vol.tcl line ~450:
    set Nv_(ShadeStyle) [Nvol$curr slice get_drawmode]
I followed "mode" into lib/ogsf/GVL2.c GVL_slice_get_drawmode()
and then *gvl to gvl_get_vol() in lib/ogsf/gvl.c, but then I get lost.
uninit'd variable?
Hamish
return (TCL_ERROR);
uninit'd variable?
Hamish
Looks like.
If nviz is called with -q and a volume + isosurfaces are added -> nviz segfaults.
I have corrected the uninitialized variable:
cvs server: Diffing .
Index: gvl_calc.c
RCS file: /home/grass/grassrepository/grass6/lib/ogsf/gvl_calc.c,v
retrieving revision 1.3
diff -u -r1.3 gvl_calc.c
--- gvl_calc.c 9 Feb 2006 03:08:57 -0000 1.3
+++ gvl_calc.c 9 Jul 2006 13:48:54 -0000
@@ -444,7 +444,7 @@
     int x, y, z;
     int i, a, read;
- geovol_file *vf;
+ geovol_file *vf = NULL;
     geovol_isosurf *isosurf;
     data_buffer *dbuff;
and it works for me now. But i am not sure if this realy fixed the
problem.
But there is a second problem. If i start nviz with the option "volume"
and a valid volume map e.g.: nviz volume=vol
nviz receives a segmentation fault. This seems to be related to this line:
/home/grass/grassrepository/grass6/visualization/nviz/src/togl_flythrough.c:786
buf_vol = Tcl_GetVar(interp, "volume", TCL_GLOBAL_ONLY);
buf_vol is a NULL pointer and the program segfaults while the atoi(buf_*) calls later.
Something realy strange happens here if a volume map is provided. Maybe the parsing
functionality for volume maps is broken?
I have no clue where this functionality is defined, so i'm not able to fix this. :frowning:
Best
Soeren
> uninit'd variable?
> Hamish
Looks like.
Index: gvl_calc.c
@@ -444,7 +444,7 @@
     int x, y, z;
     int i, a, read;
- geovol_file *vf;
     data_buffer *dbuff;
problem.
I don't think so. In that function (gvl_isosurf_calc), "vf" is only
read if the variable "read" is non-zero. But the only places which set
"read" also set "vf":
