[GRASS-dev] [bug #4725] (grass) nviz crashed while volume visualisation
[ http://intevation.de/rt/webrt?serial_num=4725 ]
I just tested the volume with the Slovakia3D dataset:
it works again. Whatever happened, but NVIZ volume
visualization seems to be back.
GRASS 6.1.cvs (slovakia3d):~ > nviz dem500 volume=precip3d.500z50
Loading Data
Update elev null mask
Loading Data
translating colors from fp
recalculating normals...
% [Raster MASK present]
Someone please test this with 6.1.0RC1. Enter Panel -> volume
-> add -> constant -> 1000 to visualize an isosurface. Or
read the README of the dataset.
On Wed, Aug 02, 2006 at 09:54:06PM +0200, Markus Neteler via RT wrote:
Loading Data
Loading Data
Ok, it crashed in a second run.
I debugged a problem in togl_flythrough.c, line 800:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1239013664 (LWP 24023)]
0xb734e327 in __strtouq_internal () from /lib/tls/libc.so.6
(gdb) bt full
#0 0xb734e327 in __strtouq_internal () from /lib/tls/libc.so.6
No symbol table info available.
#1 0xb734e0cf in __strtol_internal () from /lib/tls/libc.so.6
#2 0xb7a2f2d0 in atoi (__nptr=0x0) at /usr/include/stdlib.h:333
No locals.
#3 0x08068d93 in Ndraw_all_together_cmd (data=0x8073f40, interp=0x8079b18, argc=1, argv=0xbf8a89ec)
    at togl_flythrough.c:800
        buf_surf = 0x0
        buf_vect = 0x0
        buf_site = 0x0
        buf_vol = 0x0
        buf_north_arrow = 0x0
        arrow_x = 0x0
        buf_label = 0x0
        buf_legend = 0x0
        buf_fringe = 0x0
        buf_is_drawing = 0x0
#4 0xb76e3c86 in TclInvokeStringCommand () from /usr/lib/libtcl8.4.so
#5 0x08073f40 in script_mode ()
#6 0x08079b18 in ?? ()
Since all the buf_xxx stuff is 0x0, atoi() crashes.
Not sure if this is related to the recent togl changes.
> Loading Data
> Loading Data
(gdb) bt full
No locals.
        buf_surf = 0x0
        buf_vect = 0x0
        buf_site = 0x0
        buf_vol = 0x0
        arrow_x = 0x0
        buf_label = 0x0
        buf_legend = 0x0
        buf_fringe = 0x0
It might be related to the new version of Togl. Or a different version
of Tcl/Tk, or some other change to NVIZ.
The problem is that the Togl canvas is being redrawn before the
variables have been created. As the canvas can be redrawn at any point
after it has been created (or even during creation), it is necessary
to initialise all of the above variables before creating the canvas.
Whilst creating them later and simply hoping that the canvas won't get
redrawn first might work, it's an extremely fragile "solution".
