Actually, this is making it overly complicated. It should actually be
as follows.
g.region -u save=region.save # save a region but don't change WIND
WIND_OVERRIDE=region.save
export WIND_OVERRIDE # use region.save like WIND but don't change WIND
g.region rast=$input
do_stuff()
unset WIND_OVERRIDE # unneeded if script exits, but good hygiene
g.remove region=region.save
I am not sure that the region code is 100% working as you expect......
step by step:
it wouldn't change it anyway as no modifying parms were given? (like
rast=)
ok
but now you have in fact changed the region [written to the WIND file]?
(but the following modules are using WIND_OVERRIDE so you don't
notice)
do_stuff()
I'll work through a spearfish test as I don't have my head around this
fully:
G> g.region -d
G> g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928010
south: 4913700
west: 589980
east: 609000
nsres: 30
ewres: 30
rows: 477
cols: 634
G> g.region -u save=region.save
G> g.region -p
[same as above]
G> WIND_OVERRIDE=region.save
G> export WIND_OVERRIDE
G> g.region -p
[same as above]
G> g.region rast=elevation.10m
G> g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928000
south: 4914020
west: 590010
east: 609000
nsres: 10
ewres: 10
rows: 1398
cols: 1899
[changed!]
G> r.univar roads
100%
total null and non-null cells: 2654802
[1398*1899 = 2654802 so region being used is elevation.10m not
region.save!]
G> unset WIND_OVERRIDE
G> g.remove region=region.save
#final:
G> g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928000
south: 4914020
west: 590010
east: 609000
nsres: 10
ewres: 10
rows: 1398
cols: 1899
[left in elevation.10m's region, not starting region!]
trying with Glynn's method:
You don't need to touch the current region at all. Just:
g.region rast=$input save=region.tmp.$$
WIND_OVERRIDE=region.tmp.$$
do_stuff()
g.remove region=region.tmp.$$
G> g.region -d
G> g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928010
south: 4913700
west: 589980
east: 609000
nsres: 30
ewres: 30
rows: 477
cols: 634
G> g.region rast=elevation.10m save=region.tmp.$$
G> g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928000
south: 4914020
west: 590010
east: 609000
nsres: 10
ewres: 10
rows: 1398
cols: 1899
[rrrrr. wrong. above needs "-u". let's try again, also with --o for
safety]
G> g.region -d
G> g.region -u rast=elevation.10m save=region.tmp.$$ --overwrite
G> g.region -p
nsres: 30
ewres: 30
[good; now region is still original but elevation.10m's region is saved]
G> WIND_OVERRIDE=region.tmp.$$
G> g.region -p
nsres: 10
ewres: 10
rows: 1398
cols: 1899
[encouraging]
G> r.univar roads
100%
[we are using 10m res region from region.tmp.$$]
G> cat $MAPSET/WIND | grep res | grep -v resol3
e-w resol: 30
n-s resol: 30
t-b resol: 1
[WIND is untouched, good]
G> g.remove region=region.tmp.$$
G> g.region -p
nsres: 30
ewres: 30
rows: 477
cols: 634
back where we started in default region.
perhaps this accounts for some occasional gis.m weirdness?
Hamish
