[GRASS-dev] [bug #4764] (grass) Give NetBSD a distinct configuration section in aclocal.m4.
Markus: To decode the attachment, copy and paste into a text file and save
with a .uue extension. Then open with Winzip and you can extract the attached
file from there. Of course this only works on Windows :wink: You should be able to
achieve the same with the 'uudecode' command on Linux but I didn't get it
working...
Brook:
Patch applied and in CVS now. Please test.
