this bug's URL: http://intevation.de/rt/webrt?serial_num=4796
Subject: v.digit: $mapname in the title bar
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: 2006.07.05
The v.digit title bar displays "v.digit - $mapname". Not the name of the map, but "$mapname" literally.
Maciek
In the source code is the following comment:
# I'm not sure how to grab the map name, so I'll leave it obviously broken
# in the hope someone will fix it. If you comment out the following line,
# then the toolbox window takes on the map name! argh! We want both.
wm title . "v.digit - \$mapname"
