[GRASS-dev] [bug #4916] (grass) v.in.ogr should allow choice of cat column
this bug's URL: http://intevation.de/rt/webrt?serial_num=4916
Subject: v.in.ogr should allow choice of cat column
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: cvs_head_20060724
V.in.ogr creates a new cat column at import. It would be nice if one could tell v.in.ogr which column in the attribute data it should use as cat. Currently, I have to use v.reclass to create a new vector file with the desired category values.
Moritz
