Installed Grass 6.1 using cygwin. Once installed, it opened up.
I started to 'Create location from EPSG' only to find that folder proj does
not exist. Searched in surrounding folders with no luck.tried installing proj package from cygwin again (twice) with no change in
results
Where is you share/proj/epsg file located on the disk? And what path is there
in the "Path to EPSG-codes file" field? If these paths are different, press
the "Browse..." button, navigate to where the 'epsg' file shipped with your
proj instalation is located, then try again.
Does that work?
Maciek
