this bug's URL: http://intevation.de/rt/webrt?serial_num=5002
Subject: lib/gis/color_str.c does not compile
Platform: Solaris2.x/Sparc
grass obtained from: CVS
GRASS Version: cvs checkout 20060814
When compiling with Sun C 5.5 2003/03/12 the following error is reported from file color_str.c in lib/gis/:
"color_str.c", line 54: zero or negative subscript
"color_str.c", line 57: warning: syntax error: empty initializer
"color_str.c", line 112: warning: statement not reached
cc: acomp failed for color_str.c
A workaround is to change row 46:
#define NUM_COLORS 1
and to uncomment line 56 to have one value in the table:
{"purple", 128, 0, 255}
It seems that a static construct without explicit initialization is not legal, at least in this compilers opinion.
Harri K.
Zero-size arrays aren't legal C; they're a gcc extension.
It appears that the code in question was left in as "documentation" of
the previous behaviour.
Fixed in CVS.
